Single Mass Flywheel--
  • Jonsku
    • Oct 2004
    • 566
    #46
    That's why people don't use twin-mass flywheels with single-mass flywheel clutches ...
    Just get proper single-mass FW done by a local machine shop, will save you tons of headache and delete 10kg of rotating mass :)
    - E34 M5 (x 2) -
    - E30 V8 Cabrio "Kylpyamme" -
    - Alpina D10 Touring #33/94 -
    - E46 318i Touring -
    - Toyota Hiace 4wd -
    • JGood
      • Jan 2004
      • 7959
      #47
      In a perfect world, we would all have custom made, perfect working parts, with no regard to cost, wouldn't we?
      Obviously I'm aware that the single mass lightweight flywheel is the best option. But I'm attempting to find a way to avoiding spending $1200+ on my clutch/flywheel setup. If I can get that center portion machined down, I will have a useable setup for about $400.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • Jean
        • 18228
        #48
        I am leaning towards using the JB e34 530i flywheel wiith the 530i 5speed tranny so that should let me use 240mm clutch kits.
        Any specific kit you guys recommend that will bolt right in w/o any modifications ?
        • JGood
          • Jan 2004
          • 7959
          #49
          Jean, remember my posts in the other thread... I don't think JB makes a lightweight flywheel for the 530 V8, the one listed on their site is for the Euro m30 car (unless they've told you differently).
          • Jean
            • 18228
            #50
            Here is what they told me below after I asked what would work for e34 or e39 v8 and e34 5 speed transmission and 240mm kits
            " Jean, The aluminum flywheel replacement we offer for the late (6/96-'03) E39 540i M62 4.4L sounds like it would be the ticket and it accepts a 240mm clutch disc. Our PN is 520-150-240, weighs approx. 13.0 lbs. and sells for $798.00."
            • JGood
              • Jan 2004
              • 7959
              #51
              Right, that's the setup that Bruce is running.
              • Jean
                • 18228
                #52
                Oh thats right, the one the list for under $700 for 530i is for m30..DAMNIT.
                This is getting expensive lol
                • JGood
                  • Jan 2004
                  • 7959
                  #53
                  Apparently the reason the m62 flywheel is so much more expensive, is the timing ring. UUC buys the timing ring from BMW and installs it on their lightweight flywheels. The ring is $140, hence the price difference.
                  The reason I know this is because I just got off the phone with UUC, I called them to order the lightweight e39 540i flywheel. UUC gave me a bangin price, cheaper then the JB that BW & Turner sells, so screw it.
                  Anyone want the e39 540i dual mass to play with?
                  • Jean
                    • 18228
                    #54
                    Is this what you ordered - LWFM62 ? That will work with 5speed tranny though?
                    • JGood
                      • Jan 2004
                      • 7959
                      #55
                      That is the whole flywheel/clutch package. I just got the flywheel. It's not listed on their site.
                      Just responded to your PM with the details...
                      • Jonsku
                        • Oct 2004
                        • 566
                        #56
                        Yap, it's an expensive game but on the other hand you'll end up having a flywheel that won't ever die :)
                        All M60 / M62 / S62 flywheels are the same regards to gearbox, the clutch disc makes the difference..
                        - E34 M5 (x 2) -
                        • Jean
                          • 18228
                          #57
                          Yep, it's a critical piece so :) I just wasn't sure if B30 vs B40 / B44 flywheels are interchangable or not (with matching clutches).
                          • Taras
                            • Aug 2012
                            • 1
                            #58
                            Good afternoon.
                            Prompt please, on mine М62B44TU it is necessary to change the Double mass wheel.
                            Tell if to put please from JBR firm and what set of coupling should be put, if I use the 6th high-speed transmission?
                            JBR the facilitated mass wheel
                            Clutch disk from М30.
                            And clamping SAC mechanism standard M62TU
                            Such option will work?
