The semi-Comprehensive M60b40 into E30 swap Q&A
  • JGood
    • Jan 2004
    • 7959
    #271
    Originally posted by LoneWolf
    Hmmmm saw this post in my thread.
    So you notched the pan, but didn't lower the engine anymore? Over and inch of space seems like a little much to me
    Those are pics from a car that is in the build process. He modified the pan but did not yet build the 'lowered' mounts.
    I have my pan notched, and made mounts about 1" lower then the normal mounts. I took my own measurements, and the crank bolt is exactly where the m20 crank bolt was.
    The common theory for the engine needing lowered about 3/4" is correct. This is done by either using subframe spacers, or by notching the pan and lowering the engine via custom mounts.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • LoneWolf
      • 402
      #272
      Ah ok. That makes sense then, thanks for clarifying.
      I was reading it as he hadn't lowered the engine yet and those were his measurements.
      • LoneWolf
        • 402
        #273
        Has no one considered sectioning the top of the subframe?
        • JGood
          • Jan 2004
          • 7959
          #274
          That would require lowering the steering rack even further, affecting bump steer in the same way subframe spacers do.
          • The Dark Side of Will
            • Jun 2010
            • 2796
            #275
            Like JGood said, the problem isn't interference between the pan and the subframe, it's the pan and steering rack, AND the rack can't easily move because that would wreak havoc with bump steer.
            However, the rack could be moved down if something like this were used to lower the tie rods as well (and the tie rod ends were replaced with standard rod ends).
            http://www.speedwaymotors.com/Adjust...Heim,3333.html
            • DDF_Dutchie
              • Aug 2012
              • 22
              #276
              Hi guys,
              Im in my m60b40 swap right now.
              I'm currently busy with preppin the engine for the swap, engine bay is 80% ready.
              Still I have a couple of questions:
              For my setup im using a 5-speed with M5(E39) flywheel and M3 (e36) clutch. Will this work? so far I read it will, but I still would like some confirmation.
              And for putting the engine in, would you guys recommend putting the transmission on the engine or mount it to the engine when it already is sittin in the bay?
              BTW im from the Netherlands so please excuse me if I make grammar mistakes
              • Simple_Smith
                • Aug 2011
                • 585
                #277
                bumping an old tread because I had a project car dumped in my garage. 85 325e with a 94 M60 and 99 G420 trans. It has an auto harness I want to clean up. Does the DME need ANY info from the trans computer for it to run properly? I understand there will be CAN codes but that doesn't concern me. Can I simply cut out all the wiring from the auto trans connector back into the harness splices?
                1989 JDM-Tech 2
                2010 335 D for daily
                • DesertBMW
                  • Aug 2011
                  • 1038
                  #278
                  OBD1 Bosch DME will not need any information from anything else to run properly.
                  • Simple_Smith
                    • Aug 2011
                    • 585
                    #279
                    excellent, thank you
                    1989 JDM-Tech 2
