My BMW V8 engine build thread
  • bmk
    • Feb 2011
    • 598
    #151
    Major props on your build looks great!!!
    On a side note it makes me happy that I went with an ls based swap in my car. The complexity of the m60/62 is crazy compared to my ls based v8. I literally rebuilt and assembled the entire motor in 2 days including having the crank ground and glazing the cylinders.
    Worlds 1st LS powered e30 cabby.
    Cab
    billac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
    Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
    Shaggin Wagon
    : 01 325xiT 5 speed
    91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
    88 CRX OEM+ 42mpg DD.
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #152
      Originally posted by zogs
      ok but how is with m60 managment on b44 block? Doesn,t b44 need more fuel than b40?
      The MAF measures the increase in airflow, the DME adds fuel accordingly.
      • zogs
        • Apr 2014
        • 28
        #153
        so you say that it's for 100% safe to drive with m60b44, the engine will work perfectly and nothing will go wrong?
        Is some dyno tests with this engine, and some reviews from these engine owners
        • Jonsku
          • Oct 2004
          • 566
          #154
          Yes.
          It works well, when mapped pushes out around 320..330hp / 420..440Nm.
          - E34 M5 (x 2) -
          - E30 V8 Cabrio "Kylpyamme" -
          - Alpina D10 Touring #33/94 -
          - E46 318i Touring -
          - Toyota Hiace 4wd -
          • zogs
            • Apr 2014
            • 28
            #155
            Originally posted by Jonsku
            Yes.
            ou 320hp sounds good, what do you mean by mapped, you think chip tuning m60ecu?
            • JGood
              • Jan 2004
              • 7959
              #156
              My m60b44 runs perfectly fine on both a stock m60b40 chip and an aftermarket chip, both in the stock 404 DME. It idles great, gets the same gas mileage as my m60 did, and pulls hard to redline. I don't see any reason to go with a standalone system. If you want to get the most from the engine, you can get a custom tune made for the 404 DME.
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
              • zogs
                • Apr 2014
                • 28
                #157
                ok thanks, you helped me alot, have you put your car on dyno with m60b44?
                • zogs
                  • Apr 2014
                  • 28
                  #158
                  and how much KM have you drived woth the hybrid engine?
                  • JGood
                    • Jan 2004
                    • 7959
                    #159
                    No, I only got it running last week. I have about 200 miles on it.
                    • zogs
                      • Apr 2014
                      • 28
                      #160
                      ou, that's not so good :D. yes there would not be a problem to run it, but I am worried about what will hapen for example after 2000km, becouse of the bigger copresion, smaller combustion chamber. I am thinking that maybe should put fuel pressure regulator and
                      more productive pump, to give in more fuel.
                      • JGood
                        • Jan 2004
                        • 7959
                        #161
                        ou, that's not so good :D. yes there would not be a problem to run it, but I am worried about what will hapen for example after 2000km, becouse of the bigger copresion, smaller combustion chamber. I am thinking that maybe should put fuel pressure regulator and more productive pump, to give in more fuel.
                        Well, I have no idea why you'd do that, but you can do whatever you want...
                        • zogs
                          • Apr 2014
                          • 28
                          #162
                          Then you are for 100% sure that the engine resource will be long and nothing will happen? Maybe you know some person who has already derived some time with hybrid engine?
                          • zogs
                            • Apr 2014
                            • 28
                            #163
                            Other question, other block I have b44 banks, aren't there different pistons? Can I put on it b40 heads?
                            • JGood
                              • Jan 2004
                              • 7959
                              #164
                              Lol, how could I be 100% sure how long my engine will last? Not to mention the variables involved with that (use/abuse, oil type, climate, the fact that my block already had 200k miles on it before the build, etc...). That's just a ridiculous thing to ask.
                              It's not a fully built race engine with wild cams and ITB's that needs tuned from scratch. It may need some tweaking to the maps to get ideal AFR's and ensure there's no knocking, but that is all well within the capabilities of the stock DME and fuel injection system.
                              • zogs
                                • Apr 2014
                                • 28
                                #165
                                no you misunderstand me, I am thinking if there wount be some detonation or something like that, what will burn pistons, or simply blow engine, becouse of m60 ecu and heads.
                                I am asking such a question, becouse one person, who has same hybrid, with vems, m5 intaka and so an, (he is drifter and mechanic) he says that without VEMS there can something go wrong.
                                Of course maybe he is wrong, therefore I want to ask some other people review who has this hybrid engine.
                                In internet there are planty of these projects and instructions how to build it, but NONE project is fully completed, with dyno tests and drived for example more than 2000km, so yes... therefore I am thinking to put stock m60b40 engine,and drive with no worries, or make hybrid, becouse I also have b44 engine.
