My BMW V8 engine build thread
  • The Dark Side of Will
    • Jun 2010
    • 2796
    #136
    Generally...
    I'm interested in converting my S62 from u-shaped guide to idler sprocket... just wanted some info
    • Jean
      • 18228
      #137
      I have an M62 block with the U-shaped guide and no idler sprocket.
      The M60 stuff bolts right on. What do you need specifically, I'll take pics for you?
        • Jun 2010
        • 2796
        #138
        Based on photos I've seen of the S62 block and the M60 block, it looks like the idler sprocket mount will bolt right up to the block, but the lower mount for the right bank's upper chain guide isn't present in the S62 block, due to the different routing of the coolant passages.
        I was just curious... Wasn't expecting you to go out of your way.
        What I really need to do is get that damned Jeep 4.0 off my engine stand so that I can put my S62 on the stand and take the timing cover apart to see.
        • Jean
          • 18228
          #139
          Well, I don't have an S62. (only have M60 and M62)..so not sure how that would help you....
          • fanboi
            • Sep 2012
            • 136
            #140
            Originally posted by Jean
            Down to just flywheel / clutch kit
            Have you sorted this out yet? as far as knowing what you are going with? I only ask because I have the same tranny. Im glad you took it apart to look into everything. Looking forward to the comparisons of both engines.
            John
            Odd man out
            Vanos=Very Aggressive NOS???
            • Jean
              • 18228
              #141
              I had to re-do the timing the other day, somehow got the two cams out of phase...not sure how that happened with cams tools
              Anyways, timing is set, new knock sensors in place, manifold, tb,rear pcv ready to be bolted down.
              Haven't installed the upper timing cover gaskets yet, needs to double-check the torque specs for a) sprockets bolts b) upper timing cover bolts c) valve cover nuts.
              Waiting for rebuilt / flow matched injectors to arrive. Water pump/tstat is next once I figure out exactly how the rear water pipe needs to be modified to match the e30 firewall/heater core.
              • slammin.e28
                שמע ישראל
                • 12054
                #142
                Bolts right on?
                Did you ever take pics?
                I'm thinking of picking up an M62 powered Rover sometime and would like to do this when I decide to go through the timing components.
                • Jean
                  • 18228
                  #143
                  Yes, the m60 timing pulley and guides bolt right onto m62 block.Check post 43
                  • Wh33lhop
                    • 11705
                    #144
                    If there is a bit of slack in the wrong place, this can happen.
                    Love that double row chain. This thing is sexy, can't wait to see it go in.
                    That's what she said.
                    paint sucks
                    • alco
                      • Feb 2013
                      • 197
                      #145
                      Jean,
                      So if I try to pass an M62 through CA BAR as an M60 and they catch me, what exactly happens then?
                      Velocity Motor Works
                      1972 2002
                      1983 533is
                      1987 325is (Roxanne)
                      1988 M6
                      1989 M3
                      1989 325ix (Darth Maul)
                      Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
                      • Jean
                        • 18228
                        #146
                        Originally posted by alco
                        Jean,
                        I don't know, your record get recorded in their BAR system by the VIN? Call and ask them.
                        • zogs
                          • Apr 2014
                          • 28
                          #147
                          JEAN have you made your m60b44?
                          I have b40 heads , b40 and b44 block, I want to make m60b44 with m60ecu, but I am worried about engine, will it work correctly? becouse of bigger compresion and smaller combustion chamber.
                          I have talked about this to local mechanic/drifter, he has also m60b44, but with VEMS, sport camshaft, m5 intake,exhaust, and he says that there could something go wrong with oem ecu, he recommend to put VEMS, and to adjust it correctly.
                          • Jonsku
                            • Oct 2004
                            • 566
                            #148
                            It works, the adaptation in the DME can handle the difference.
                            However, you should get the DME mapped if you want to pull everything out of the engine.
                            - E34 M5 (x 2) -
                            - E30 V8 Cabrio "Kylpyamme" -
                            - Alpina D10 Touring #33/94 -
                            - E46 318i Touring -
                            - Toyota Hiace 4wd -
                            • zogs
                              • Apr 2014
                              • 28
                              #149
                              ok but how is with m60 managment on b44 block? Doesn,t b44 need more fuel than b40?
                              m62b44 has only 20nm powerful than m60b40, is it sense to make hybrid?
                              • Jonsku
                                • Oct 2004
                                • 566
                                #150
                                As I said, it works fine. The adaptations can handle the difference.
                                With B44 block you get 10% more displacement and 10% more compression without basically any additional cost so why not? :)
                                - E34 M5 (x 2) -
