Depending on the hardness of the parent material, different abrasives might be required.
For example, the Cadillac Northstar uses centrifugally cast grey iron bore liners. These are much harder than the nodular iron blocks of traditional Chevy engines. The silicon carbide stones used to hone the bores of Chevies just polish Northstar bores. Northstars need to be honed with aluminum oxide stones.
I'm not sure of the specifics, but I do know of a shop that has done that in the past.
However, the ultimate goal of honing is to produce a bore surface with specific roughness characteristics. Use whatever tool gets the job done.
