E30 M3 S62 Build - Loads of queries about 4x4 drivtrains
  • DER E30
    • Sep 2013
    • 2343
    #391
    Originally posted by The Dark Side of Will
    I frequently used to pick out R when going for 1st when I first started driving BMW's... but got used to it. The TR6060 in whatever form will just be a matter of getting good at using it.
    I'd rather find R when looking for 1st than R when looking for 5th!
    -Christian
    • iansane
      • 1342
      #392
      Figuring out how to deal with the reverse lockout solenoid will be fun... I may have to machine a new turret box to accept it.
      Yeah, seriously. Hopefully there won't be any interference between the mechanicals of the tr6060 shifter assembly and the reverse lockout....
      Wait, am I blind? Where is the 6060's reverse lockout?
      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
      • The Dark Side of Will
        • Jun 2010
        • 2796
        #393
        It's hard to see in this photo, but it's on the "top" side of the extension housing, with the electrical connector pointing away from the camera.
        So I'd need a turret housing that would accommodate both the shifter as pictured and the Corvette reverse lockout solenoid. AFAIK, GM never made anything for that, so I'd have to machine the housing (and probably a part or two inside) in order to make it work.
        • turbotarzan
          • Oct 2013
          • 23
          #394
          Forgive my poor english but what does this solenoid do? I know what a solenoid is but what does this one do?
            • Jun 2010
            • 2796
            #395
            R is to the right of 5th. The solenoid normally keeps you from shifting into R. When energized, it allows you to shift into R.
            There's also the CAGS solenoid, but it's ok to leave that one out (as long as you plug the hole).
            • DER E30
              • Sep 2013
              • 2343
              #396
              The CAGS one is stupid as hell!!! I got a six speed for six speeds!!! LOL
              -Christian
                • Jun 2010
                • 2796
                #397
                No joke... Stoopid EPA
                • turbotarzan
                  • Oct 2013
                  • 23
                  #398
                  And CAGS is???
                  Ok, but that R solenoid should not be a problem to connect to a switch, right? Or is it dependent of some ECU or similar?
                    • Jun 2010
                    • 2796
                    #399
                    In the original application, the reverse lockout is operated by the ECM, but I've read that it can work fairly well when operated by a switch on the brake pedal.
                    CAGS = Computer Aided Gear Selection
                    It's an emissions/fuel economy bandaid that under certain circumstances (RPM, Load, etc.) will lock out 2nd gear in such a way that when you try to shift from 1st to 2nd, you shift straight from 1st to 4th.
                    • turbotarzan
                      • Oct 2013
                      • 23
                      #400
                      That's retarded! Why would a car like the vette have something like that? It's a sportscar! That one is being eliminated at once. The reason why i want to drive stick is because I! want to controll the gears, not some ECM...
                      • Northern
                        • 5151
                        #401
                        haha I remember my dad's WS6 with CAGS. It drove him crazy when he first got the car.
                        Originally posted by priapism
                        Originally posted by shameson
                        • Turk
                          • 223
                          #402
                          Wow, My thread has been going off and I had no idea :) Glad Its helping people share/gain info!!!
                          I will soon be getting back into this swap! Watch this space... :)
                          Plug and Play S54 & S62 loom/Ecu Kits - Fit you engine to ANY car!!!
                          M50 Sump Baffles
                          High Torque Clutch Kits
                          Custom Flywheels
                          E30 Engine Conversion Kits
                          http://www.bmw.ergen.co.uk
                          LIKE our Facebook page for regular car porn :)
                          http://www.facebook.com/ergenltd
                          • DER E30
                            • Sep 2013
                            • 2343
                            #403
                            Waiting on progress pics!
                            I don't get why the CAGS solenoid has to be on the side of the trans and the R solenoid is on the top of the vette trans... Seems like it would have been better for us if they were reversed... Then the R solenoid would be easier to run, and everybody hates CAGS anyway, 'cause it's BS LOL.
                            -Christian
                              • Jun 2010
                              • 2796
                              #404
                              I don't think GM designs their transmissions for people to put them into '30's pickups or '80's BMW's... ;)
                                • Jun 2010
                                • 2796
                                #405
                                I'm stealing your photo to put it right next to mine:
                                Originally posted by DER E30
                                IMG_4599 by Der E30, on Flickr
