MMP M62B44 Build Project "Jack-N-Coke"
  • MonkeyMadness
    • 3251
    #646
    So I was able thankfully to save my weighted shift rod...
    It looks bad in the picture it got munched hard sadly but thankfully I was able to repair it to it's splendid glory.. Out of all the carnage this was the one thing that bothered me the most... I dreaded making another one and I was so proud of it when I first built it..
    • delamaize
      • Nov 2013
      • 1431
      #647
      [ATTACH]100019[/ATTACH]
      How much of a difference does the weighted rod make?
      Dumpster Fire Pilot
      • MonkeyMadness
        • 3251
        #648
        tons... this linked with an AKG it makes our stock trans box feel and shift like racing boxes...
        IF you get the right weight the throw is firm but effortless...
        • The Dark Side of Will
          • Jun 2010
          • 2796
          #649
          Is that a crack I see in the countersink for the middle hole? It's right in the middle of the small patch of glare from the light (flash?)
          • MonkeyMadness
            • 3251
            #650
            wow looks like it, but thankfully it's just chipped paint.
            • MonkeyMadness
              • 3251
              #651
              will a Z3 e36 328 driveshaft work?
              I found 1 or 2 there Z3 with the 328 motor and manual trans and the sticker on the shaft it self say E36?
              are the lengths the same?
              • JGood
                • Jan 2004
                • 7959
                #652
                No, it's over an inch shorter. You can look up the lengths of the drive shafts on realoem.com, bmwfans.info, etc...
                You need something 1275-1285mm with a 4 bolt rear flange and a 96mm diameter / 12mm bole hole flex disc. e36 328i, e30 m3, and 5/86+ 325e (they can be hit or miss...) should work. I don't know of any others.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • MonkeyMadness
                  • 3251
                  #653
                  Would a 4 bolt e46 m3 driveshaft work?
                  Sent from my SM-N910P using Tapatalk
                  • MonkeyMadness
                    • 3251
                    #654
                    Score!
                    Snagged an fresh e36 328i manual driveshaft out side of Glendora. 3hr round trip. Ujoints feel nice and smooth
                    So does the csb but it also rocks fore and aft so i will be replacing that.
                    • 36brua
                      • 689
                      #655
                      Ah life is good now !!
                      change guibo and go
                      My CA legal M60 swap
                      The happening in our garage
                      • Denny
                        • Jan 2010
                        • 822
                        #656
                        Thats life i guess...good luck...bad luck...repeat! Happy to hear about this man good find...... M62 e30's keep on living...
                        Denny
                        ___________
                        1990 BMW red 325IC M30B35 all stock Girlfriends ride
                        1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                        Blogs:
                        http://bmw325e30.blogspot.com/ (restoration)
                        http://bmw325e30turbo.blogspot.com (Twincharge M20)
                        http://bmw325e30m62b44.blogspot.ca/
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #657
                          The e36 csb doesn't work anyways. Need to install one backwards from an e30.
                          john@m20guru.com
                          Links:
                          • MonkeyMadness
                            • 3251
                            #658
                            Got the drive shaft and under car completely broken down and awaiting ordered parts.
                            should all fall back together quite easily.
                            Can't wait.
                            Sadly after this weekend I will be working straight for the need 6-8 weeks
                            which includes a trip to Canada, then Scottsdale, then a Palm Springs before I get some time to myself, not to mention some were in there I will have to fit in a Birthday weekend at Legoland. My little guy is turning 6yrs old...
                            I may not have it road worthy till the November...ugh
                            • MonkeyMadness
                              • 3251
                              #659
                              Yep all finished. Just need 3 more bolts 12mm x 1.5 x 58 and 3 matching 12mm x 1.5 locking nuts and I'm burning tires again...
                              • Denny
                                • Jan 2010
                                • 822
                                #660
                                Awesome man now lets see some burnouts !! my car is done for the year looks like it.... winter is coming over here real fast and wont have another engine in it before :( ... at least I can see yours go and imagine lolll
                                ahhh well this winter I may bring a big surprise spring 2016:devil:
                                Denny
                                ___________
                                Blogs:
