I hope my steering wheel smacks my face and knocks me out before my 3 foot long remote brake booster rod gets rammed into my nuts.
How to make a custom steering shaft on the cheap!
Hahahahaha funny shit right there
Great thread, to the OP thanks for the ideas, exactly what I need for my swap!
Sent from my DROID2 using Tapatalk 2Comment
Instagram @rebellionforgeComment
Thank you to the OP for posting this writeup. I was about to purchase the flaming river gear until I saw this.
One question though. You mentioned installing set screws to hold the centre section in position. Could you not use roll pins as an alternative? They would achieve the same outcome but not require tapping a thread.Comment
great idea but it looks to me that when its together the u-joints on each end are not at same angle as other end... (maybe just the little pics it hard to tell). maybe for this application its ok, but i know if you weld up a drive shaft like that it shakes very bad because of binding do to not being in sync. if this is binding do to not getting set up in sync it will probably have stiff spot in wheel and be hard on the joints... or maybe it tottaly fine in this application..91 e30 318is M50 SOLD
http://www.r3vlimited.com/board/showthread.php?t=149570
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370Comment
I did this with a z4 steering shaft for z4 rack into i6 24v e30; shortened welded solid. Its held 30++ hours of wheel to wheel racing with contact and its been great.
if one desires a cleaner non powered rack for a v8 it would also be a good choice.
The z4 steering shaft is similar to e46 but its designed telescoping; has some ball bearings it rides on.
The e46 shaft as op has shown is solid steel and seems much more work able.
Sent from my SAMSUNG-SGH-I337 using TapatalkOBD1 M54/M52TU swap as a M50b25
Resurrecting an old thread.
How did you correct the issue with the clamping bolt from the e46 shafts? It protrudes into the splined section.
Newer steering racks have a 'notch' cut out of them for this
but the e30 steering shaft doesn't.
Did you cut your shaft or did you do something to the bolt?Last edited by badwella; 04-07-2015, 12:23 PM.P.O.S 1989 325is - aka Project Sh*tbox
Project Shitbox - Restomod and other stuff - soon to be 328isComment
Very nice! thank you very much for sharing this.. next time I remove my engine...Denny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/Comment
I slipped on the steering shaft, then drilled just drilled out a notch so it was perfectly aligned. Super easy and doesnt harm a thingWorlds 1st LS powered e30 cabby.
Cabbillac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
Shaggin Wagon: 01 325xiT 5 speed
91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
88 CRX OEM+ 42mpg DD.Comment
To bump this back up, what's the verdict now in 2017 as far as these go for clearance with m60 swaps ?
Is flaming river still the only off the shelf option, that is ready to go?
ThanksMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
No, you can buy this E46 based setup from Garagistic. It's pretty simple to make, only took me a few hours though.Comment
