Has anyone used the B30 manual harness before? I have one and noticed that the 3.0 harness doesn't have the x20 connector on the passenger side of the harness just the diagnostic connector. Is there another way they wire it up to the e30 or should I use my 4.4 auto harness???
M60b44 #
Has anyone used the b30 manual harness??Comment
Yes, there's a sticky at the top of this forum dedicated to that exact info. The b30 harness does have an x20 connecter, just as the b40 harness does, same location.Comment
As a sidenote, B30 harness has different knock sensor connectors.- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
I will get a pic of the harness, but yeah it has the same style knocks as the 4.0Comment
Installed injectors today
Coming together soon! Ordered more things, trying to get the most power out of this this I can.
An this is my b30 harness
o
Ok I will try, n also I think I found my X20 harness connector....but it's not a circle like the rest it's a square one? Anyways I thinks it's a tad bit easier since it doesn't have to many wires running thorough it.Comment
Does anyone know what this connector is called?? I'm having trouble figuring out what this is. I was told it was pulled out of a Manual 94 530i E34 but I know that the 94 e34's had a x20 (circle plug) and this harness doesn't have that as you can see its a rectangular plug...
And like I said there is no circle plug on the harness other then the diagnostic plug
That's not an m60 harness, that's an m62 harness.Comment
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
