*Updated & only kinda shitty now!* The definitive 5.0/302 swap guide
    Originally posted by drift e302 View Post
    Cheers for the advice. You have a T5 hey? I wonder how different that is to a TKO600.
    I need about 60mm of travel for my clutch to work. currently I'm getting 30mm with a 7/8'' bore slave. If i did my maths right I believe a 1/2 should get me to that 60mm travel. or am I doing this all wrong? haha
    5/8" should double the travel.
    .875^2 = 0.765625
    0.765625/2 = 0.3828125
    Sqrt(0.3828125) = 0.619 ~ 0.625 = 5/8"
      I guess it's time for me to read through this entire thread.
        Step 1: remove donor engine
        Step 2: install into E30
        You're half way done!
          Got to look into what heads it has, and if it needs better valve springs. Probably just crappy E7 heads, so I may be looking for some GT40P heads.
          Trying to find a cheap distributor and single plane carb manifold so I can throw one of the many 650CFM Holley we have around the place on it. Also need to change the water pump to forward rotation and timing cover to suit.
            Since you're going carb you can use the garagistic pedal box + stock gas pedal +m42 throttle cable
            Look into getting a HEI distributor, really cleans up the engine bay & is easy to wire up
              By the time you get a set of GT40 heads and put better springs in them, you might as well get a used set of aluminum heads.
                Unfortunately being in Australia, there isn't an abundance of cheap performance parts available. I'd be looking at $2,500 for decent aluminium heads. Or $1,200 ish for pro comp + machining and assembly with quality parts.
                The reason I wanted to switch over to GT40P is because I want to throw some parts at it; headers, roller rockers, cam, intake manifold, valve springs etc and I don't know if what works on E7's will work on GT40/aftermarket aluminium heads when I'm upgrading it sometime down the track. I'd hate to be buying everything twice.
                Edit: After more research, it would seem only GT40P heads have specific parts and that's the headers due to different spark plug angle. Too easy. May just get a mild port clean up on the E7's in that case.
                  After market aluminium heads are well worth it in my opinion. from memory mine where around $2g for afr 165's and that pedal box is for left hand drive only =(
                  http://www.r3vlimited.com/board/showthread.php?t=322351
                    Back to my clutch problems... would i be right in saying that a 3/4 bore master travelling 38mm is only pushing my 7/8 slave travel only 18mm. somethings not right there hey?
                    by my calculations my slave should be travelling around 34mm as my slave is 12% bigger than my master
                      You should be seeing about 28mm of travel from the slave.
                      (0.750/2)^2 = .140625
                      (0.875/2)^2 = .19140625
                      .19140625 / .140625 = 1.36
                      The 7/8 slave is 36% bigger than the 3/4 master.
                        thanks!
                        So yeh, im getting nowhere near that. any ideas on what could be wrong?
                        I've bleed the system so many times. no air no leaks.
                          So there's two holes in the clutch fork, right? The rosehill kit puts your pushrod into the hole closest to the bellhousing, yes? If not that might be part of the problem.
                          I think you need an aftermarket slave cylinder guy. Either that or somehow rig an e36 slave up, I know they can use the stock cylinders.
                          The other option is to keep the e30 master and switch to a datsun 280z or zx (can't remember which), I think that's the combo e30302 is using.
                            I'm using whatever came in the rosehill kit for the T5 hydro conversion. Works like a charm. Stock E30 master.
                              well fuck me then.
                              maybe it's eurotrash that's using the e30 master + datsun slave? hardly ever hear from him
                                I'm using a 3/4" Nissan slave with the e30 master on my T5. Fabbed a bracket and had to drill a hole in the clutch fork closer to the bell housing. I think it moves about 30 - 33 mm and works great.
