Some progress over the past few days.
I was able to get the pin holes in my oil pan taken care of and began modifying my coolant crossover with the help of my friend and his tig welder.
Need to place an order for some misc. hardware and a few gaskets. Hoping if ordered tonight it will be her by the weeks end.
So I started reassembling the engine, new knock sensors, gaskets, timing things.
I will post a pic of the coolant crossover once it is done, the expansion and return line is not gonna be pretty.
Got a few questions though.
Been looking into the driveshaft modification that I will need to do, going 6-speed. I am a little confused......
Will the e36 m3 driveshaft work with my 6-speed? Or is that only for the 5-speed?
If not I could use the larger flange from one though correct?
Also anyone keep a/c on their swap or know of any builds that did? Trying to figure out how I can mount the engine mount if the a/c bracket uses the holes I need for the engine mount. And how much room the compressor will take up, if I would even have room to but the engine mount there.
Oh and I set my coil packs on, they don't feel like the clicked into the sparkplugs? Are they supposed to or do they only make contact? I am wondering if these Bosche plugs are wrong somehow?
