E30 M3 v4.1
  • gobuffs
    • Dec 2004
    • 513
    E30 M3 v4.1
    Special thanks to Randy at Epic Motorsports for getting the stock MSS60 ECU to run the motor in the E30 chassis.
    E30 M3 v1.0- stock S14....bought the car this way with a blown motor
    E30 M3 v2.0- Euro 3.2- this is the first motor swap I did. Last 5 years before I removed it and sold it
    E30 M3 v3.0, 3.1, 3.2 and 3.3- S54- firewall moved back to move motor back 5.5” inches so the dual sump pan could be kept. V3.0 met its demise at VIR where the #5 rod bolt failed (spun bearing? Dunno) and put 4 holes in the block- out both sides and into each adjoinding cylinder). V3.1 just kinda died- appeared to have overheated for some reason...root cause never determined. Took it out and rebuilt it. V3.2 died at High Plains Raceway outside Denver. Either a valve keeper broke or the 6th cylinder valves failed. Died with a whimper.
    E30 M3 v4.0 and 4.1- S65 as documented here. V4.0 was still born. Failed idling in the driveway. Appears injector 2 stuck open and washed the cylinder bore and destroyed it. Could be rebuilt but needs to be sleeved. This is v4.1.
    For those of you thinking about doing this...DON'T. 1. it makes my car less unique, and 2. it isn't easy. I6 swaps (which this chassis had 2 of- Euro 3.2 and an S54) are so much easier. You have been warned.
    The donor motor was from a 2008 E90 M3 6 speed with 59k miles on it that was totalled in a accident that caused the left front suspension to be removed from the car and the front subframe to be damaged. Overall the chassis wasn't that badly damaged.
    The weight of the E30 M3 race car that had an S54 in it (but moved 5.5” back in the chassis) was 2398 ready to race with a full fuel cell but no driver. The weight difference between the S54 and 5 speed and the S65 and 6 speed was around 120 pounds more for the S65. Only real weight saving measure on the S54 was the 5 speed gearbox and the BimmerWorld strapless flywheel and clutch setup.
    So we are going to stick this in there?
    Seriously???
    First test fit
    The transmission is ginormous. This isn't all of the tranny tunnel that had to get cut back.
    Tight fit but look good in there.
    This is where all the problems start. From the other pics you could see that I had the brake master cylinders mounted on the engine side of the firewall. This didn't work, so I had to change to inside mounts. Going to try to create an access door from above to help with getting at master cylinders in and out (and adjusting bias if need be). This pic in looking straight down the firewall.
    The other issue with this swap is the steering column and the driver's side headers. They all like to occupy the same space. Had to go with a steering linkage from The Arc Asylum to help clear the headers. This swap is not possible with a stock linkage.
    Speaking of The Arc Asylum...I needed a modified subframe from them which you can see in this pic. This was early in the motor arm fabrication phase, the motor moved back another couple inches from when this pic was taken.
    This is the motor located in the chassis and supported from above (but fully able to move any direction to get the motor exactly right). You can see the mark in the 2nd pic on the crank nut that showed the center on the motor. We measured repeatedly from side to side to keep this line in the middle of the car.
    The initial fabrication of the passenger side motor arm (done with paper). Then in metal tacked to the motor mount.
    Crappy pic but this is where you can see the space constraints on the driver's side with the steering column and headers.
    Driver's side motor arm taking shape.
    Passenger side motor arm half way finished.
    This is where the motor arms are half way finished and the motor can actually sit on the arms.
    Tranny mount taking shape
    So all that I typed up while still working on. Fast forward some. Got it in and running but had an injector problem (most likely self inflicted) that took that motor out. Bought a new motor.
    So....fast forward to now. Actually these are work in progress pics but show the details.
    Motor in car with powder coated subframe, engine motor arms and tranny mount.
    Tranny mount specifically.
    Exhaust front
    exhaust rear
    Engine in
    Where are we now? Went to as dyno Friday but wasn't able to get it tuned. Runs a bit rich but not bad. Dyno was a dynocom. FWIW (not much) stock S54s put out 270 on this dyno, stock E9x M3s do 330-340. Tuned E9x M3s do 400. Best run was 420.
    It was the plan to run a DE next weekend to shake it down then race at the Texas Trifecta II at Circuit of the Americas March 21-23, then VIR a few weeks later. However, a garage mishap with a cutoff wheel today required emergency surgery on my left thumb. The extensor tendon was cut. Racing on hold for 3-6 months. So....this project is in hold until I can grip the wheel again.
  • P Arkus
    • Dec 2012
    • 325
    Mother of God this is my dream build. Was waiting for someone to rock this engine in the E30 and document it well!!! Keep up the good work and keep us all updated!
    Originally posted by 36brua
    Isn't that what these forums are all about making stuff easier... OO no never mind this is r3v...
    Patryk:up:
    Instagram: @parkus08
    91 BMW 325is ///M-Tech II
    08 VW .:R32
    04 Audi A4 Avant 1.8TQ
      • 34839
      dang, that's crazy. bummer about your thumb!
      so the S65 ends up being 120lbs heavier than the S54? I thought the S54 was heavier? is it mostly in that gigantic transmission?
      I really want to play with one of these. I'll be able to work on the S65 DME eventually though, so maybe I can live vicariously through somebody else. :p
      • gobuffs
        • Dec 2004
        • 513
        I think the "the S65 is lighter" from BMW is bare to bare. No way the S65 is lighter.
          • 34839
          Good to know. One of the things that tickled my fancy was the supposed lighter weight. given the added difficulty I guess I'll stick to the I6. :)
          • FredK
            • 14759
            The GS6-53DZ weighs 55 lbs more than a ZF320. I believe the clutch and flywheel for both S65 and S54 are pretty heavy and around the same weight. Therefore it appears the S65, dressed for dressed, weighs more than an S54.
            • gobuffs
              • Dec 2004
              • 513
              My S54 had a BimmerWorld strapless setup. The S54 has stock. There has to be 20-30 pounds right there. So tranny plus difference in FW gives extra weight of S65. So 40-50 pounds?
              • 1990m3
                • 1180
                did arcasylum have your car for these mods?
                • gobuffs
                  • Dec 2004
                  • 513
                  No. Sent in subframe and they modified it.
                  • Vtec?lol
                    • Dec 2009
                    • 3278
                    I've always preferred a V8 in my lap rather than a sexy lady.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Originally posted by gobuffs
                      Special thanks to Randy at Epic Motorsports ...
                      Epic/Randy is local. Loved the e46 with the 6-er in it, was kind of disappointed at the v8 swap, but still cool none the less.
                      Sorry to hear about your thumb. I severed my pollicis longus in an accident involving an s52, engine hoist and mini van :( That was 1.5yrs ago and still only have about 5% ROM. Hope yours heals well. Don't need to "grip" the wheel, they keep telling me to drive with my fingertips.
                      Looks like a fun swap.
                      john@m20guru.com
                      Links:
                      • JCarp90
                        • Feb 2011
                        • 1759
                        This is nuts! Get well soon. I can't wait to see pics/videos!
                        • MJCRO
                          • Apr 2012
                          • 597
                          I'm afraid to ask how much that motor and transmission costed, haha. An S62 would've been a lot more torquey, but the sound an S65 makes at 8300 RPM is intoxicating. Awesome build man.
                          • Zacm829
                            • Jan 2008
                            • 1919
                            Cant imagine the expense and unseen fabrication that went into this build. Looks insane!
                            1987 325i-M60b44 swap
                            • MPLFoster
                              • May 2013
                              • 1490
                              This makes me happy.
                              Sub'd.
                              form.follows.function IG @mplfoster
