Are you putting the S62 throttles on to the 4.6l M60?
Very slow Alpina 4,6l V8 swap
So less time to make anything..
Get some 4,6is X5 pistons to test fit in my block.
Don't notice that arrow in piston.. I know it's wrong way.
i only measured how much that piston comes over deck. (0,06mm less than Alpina piston)
Very differend bolts in X5 vs. std M60/earlyM62 bolts.
Fantastic,,,,
Why dont you use Studs,,, ,, IMO it is the best way when you have an aluminum block
i like the ITB idea,,, this conversion should be done more often on a M/6x swapsSveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
E34 550 V12 JML
Finnish wisdom : If you want to Win,, hire a Finn
http://alpina.123.is/pictures/Comment
Where i get studs for M62?
ARP dont make them, and thats only brand to trust. (maybe)
With BMW OEM bolts i know everything goes well.
If i over thight block, cylinders goes oval.
btw.
Those bolts in upper pic are rod bolts.Comment
My 1989 e30 s52 Touring... this is Betty
My 1989 325i vert (sold)...this is Nina
My 1991 M5 (sold)... this is Veronica
Photo comparison: OEM vs aftermarket windscreen for a convertibleComment
and if you can find studs in that lenght you are a go!Sveinbjörn Hrafnsson
E34 550 V12 JML
E34 550 V12 JML
Any update ?Sveinbjörn Hrafnsson
E34 550 V12 JML
No big progress..
Yesterday i get all temp/pressure sensors for engine/Motec.
Also autosport connectors for sensors.
All sensors are made by Kulite automotive and McLaren electronics.
All pressure sensors are also temp sensors. So i get temp and pressure data from same sensor.Comment
