Very slow Alpina 4,6l V8 swap
  • jannmann
    • Jun 2014
    • 41
    #61
    My new race alternator with McLaren voltage regulator for lifepo battery
    67Ah 2,9kg
    Brakes
    e46 CSL disc's
    Perfect fit for 17" rim.
    • jannmann
      • Jun 2014
      • 41
      #62
      I have also this kind of Project.
      This proto part is from my friend who desing this for his carbrio V8 Project.
      I have to make some mods to get outputs and inlets for oil cooler.
      • jannmann
        • Jun 2014
        • 41
        #63
        Thinking that EWP setup...
        Plan is put EWP near of radiator lower output.
        Then it pumps water to adapter (which replace oem waterpump) and then water goes like oem. Under valleypan, both blocks and rise to cyl heads.
        Between heads there it's that aluminium pipe that collect both heads to one.
        That goes to radiators upper hose.
        Also In that aluminium pipe, i take small hose for expandtank (oem e30 M3 part in oem location)
        Small pipe goes also from radiators highest place to expandtank.
        That should make it self beeding like oem M3 S14 setup are.
        So i try to controll temps with EWP and try to make so simple setup that is possible.
        Any ideas ? is there any broblems?
        • jannmann
          • Jun 2014
          • 41
          #64
          I already think that i can go with my old wiring harness, but then i have opportunity to buy this part.
          So more delay's for building
          • squidmaster
            • Aug 2011
            • 2666
            #65
            I can't wait to see those CSL brakes running on the e30 those are going to be great
            • jannmann
              • Jun 2014
              • 41
              #66
              Now i have to start desing those brake adapters for Porsche calipers.
              In front i use : http://www.millway.se/distansblock-m3e30.html
              That allow to use csl dics wihtout any issue.
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #67
                Doesnt look like there is any room for calipers in that pic. If there is its gonna be one tight fit
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • jannmann
                  • Jun 2014
                  • 41
                  #68
                  Look post 61. There you see how tight fit is.
                  • Jaker
                    • Oct 2013
                    • 234
                    #69
                    67Ah 2,9kg
                    More info please? I've been running a LiFePo4 battery for 6-7 years now. It has always been OK with Honda and BMW OEM alternators, but I have been checking the alternator output carefully to ensure not more than 14.2v output. I do want a lighter alternator though and all the ones I have found have been too high voltage output with no adjustability.
                    1.5kg including all the wiring (too long) and plugs:
                    Made with 16 of these cells (4S4P):
