Very slow Alpina 4,6l V8 swap
  • jannmann
    • Jun 2014
    • 41
    Lets start with engine build.
    I was looking cheap replacement for S14B27 engine.
    So i bye Alpina F3 engine with head gasket failure.
    After disassemble, i look all the parts and think, maybe i do some tuning also before rebuilding it.
    Find some S62 parts:
    Also i take Alpina heads to flowbench.
    Heads flow 580hp/12mm valve lift (28")
    Now i know that heads are ok for better cams.
    After some search, i go with Schrick 292/284 profiles for S14 engine.
  • golde30
    • 11464
    this should be interesting.
    IG: @Baye30
    • GAbOS
      • Mar 2012
      • 523
      Sub'd !!
      • jannmann
        • Jun 2014
        • 41
        I also cut 1mm from head to get comp ration to 11:1
        Alpina cams regrind to Schrick spec.
        I also go custom shim under buckets.
        Valve springs come from Ford modular 32v engine (eibach race parts)
        Upper retainers are from S62.
        Now my valve/cam setup can handle 8500rpm.
        Of course i use 7500rpm limit, i hope my std rods can take it.
        • jannmann
          • Jun 2014
          • 41
          My alloy flywheel:
          5,9kg +Sachs SRE 765 and std e39 M5 clutch disc
          • JGood
            • Jan 2004
            • 7959
            Nice work! Do you know what caused the head gasket failure?
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • Denny
              • Jan 2010
              • 822
              Sub'd
              Denny
              ___________
              1990 BMW red 325IC M30B35 all stock Girlfriends ride
              1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
              Blogs:
              http://bmw325e30.blogspot.com/ (restoration)
              http://bmw325e30turbo.blogspot.com (Twincharge M20)
              http://bmw325e30m62b44.blogspot.ca/
              • TheTacoMan
                • Nov 2011
                • 2308
                Ah yes, European finland/Swedish build always good with you crazy fuckers.
                • Denny
                  • Jan 2010
                  • 822
                  Originally posted by TheTacoMan
                  Ah yes, European finland/Swedish build always good with your crazy fuckers.
                  LOL LOL.. so true.
                  My Euro blood got me in trouble too... I'm past that now I'm just going to take it easy with a simple M62b44 swap
                  Denny
                  ___________
                  Blogs:
                  • 1owNslo
                    • Apr 2012
                    • 334
                    rub a dub sub'd
                    10 minutes... then we invade China.
                    We'll begin with the small town of General Tso's,
                    And move to the Orange chicken province.
                    • Jean
                      • 18228
                      Hahaha right?!
                      Sub'd!
                      • jannmann
                        • Jun 2014
                        • 41
                        Thats very common on early Alpina F2/F3 4,6 engines. Weak gasket.
                        Newer 4,6l engines use mls type gasket.
                        • MattAvino
                          • Jan 2011
                          • 2147
                          I assume those motors are bored a bit, so theres not a big cylinder gap which could contribute to the head gasket issue. Looks like it was occuring at the other cyls too.
                          E30 buildy things
                          http://www.r3vlimited.com/board/showthread.php?t=195286
                          • JGood
                            • Jan 2004
                            • 7959
                            I'm surprised they didn't use MLS gaskets from the start, BMW made the switch with m62's starting in 97. What year is that engine?
                            • MonkeyMadness
                              • 3251
                              Set up on a Shim under bucket 32valve... talk about the kind of headache that will give you sleepless nights.....
