M60b40 w 5speed. Clutch and flywheel?
  • csm-e30
    • Oct 2014
    • 95
    #31
    I personally went with the TTV which alloqws you to use the 240mm M3 clutch pack. I think it was $515 shipped from the UK. Very light weight too considering.
    • Old city bimmer
      • Jun 2014
      • 1114
      #32
      I'm using the stock 530 wheel and clutch. No issues what so ever.
      323i MTEC1
      Z3 coupe
      E60 M5
      • 90-E34-M5
        • Sep 2015
        • 21
        #33
        Also heard someone used a 530i flywheel n clutch and no slipping
        I've done about 2,000 miles on my M60b40 E34 5 speed conversion and so far there's been no slipping but I'm not hard on clutches and I do think it's getting close to the limit of the clutch assembly, it's adequate.
        • csm-e30
          • Oct 2014
          • 95
          #34
          For those W the TTV & S50.....what clutch slave are you using?? My slave is not reaching the fork! :-(
          • Jony
            • Mar 2014
            • 153
            #35
            Originally posted by 325est13psi
            heres a picure of the TTV racing flywheel installed, great solution to this problem, it is steel but is still way lighter than the dual mass
            i havent gotten a e36 clutch yet but soon
            Hi i have ttv racing fw too on my e30 m62TU swap, but since i replace stock oem fw to this ttv racing one, my car doesn´t crank let´s check video->
            can someone help me with this issue?
