regular old m60 swap
  • ncrmtrsprtsE30
    • May 2015
    • 204
    #136
    Those New Injectors... I should probably do that.
    The "Because Race Car" M60 V8 Build Thread
    On Instagram Straight Flexin' #BecauseRaceCar
    • dothadance
      • Jun 2011
      • 1121
      #137
      Originally posted by jpod999
      The last one was a 3 pin sensor? That's annoying! Who did you order from?
      lol... yup. went through rockauto. "saved" like 12 dollars but in reality it doesn't matter, lesson learned.
      • dothadance
        • Jun 2011
        • 1121
        #138
        Haven't really worked on my car lately. But I went up to put some parts in the trunk and I found this 335i parked right next to me ha.
        • dothadance
          • Jun 2011
          • 1121
          #139
          Had a little play time lately. Intake mani is bolted down, back vacuum cover and throttle body are on, heater core hoses are in.
          Couple questions about the rear cover
          So the yellow arrow is for the FPR and the red is for the brake booster. What does the blue and orange go to? Don't have it in front of me right now, but it seems the orange isn't a vent?
          Also, i gave my friend my manifolds to weld up. They came out great!
          • 36brua
            • 689
            #140
            [QUOTE=dothadance;4589643]Had a little play time lately. Intake mani is bolted down, back vacuum cover and throttle body are on, heater core hoses are in.
            my experience w M60
            red vac for brakes:cap for manual brake set up
            blue vac line: cap
            orange: is side outlet even open to inside of valve ? cap / plug side outlet if it is
            see intake manifold system # 7/8 caps
            I'd also replace #3 valve and ALL 6mm socket head bolts w/ hexbolt/washer
            http://www.realoem.com/bmw/enUS/show...diagId=11_1498
            My CA legal M60 swap
            The happening in our garage
            • 36brua
              • 689
              #141
              my experience w M60
              blue vac line: cap
              • jpod999
                • Dec 2015
                • 1401
                #142
                So basically, cap everything off except for the yellow arrow?
                OBDI M62B44/6 swap
                Transaction feedback
                - jpod999
                • marshallnoise
                  • Sep 2013
                  • 3148
                  #143
                  Yep.
                  Sent from my SAMSUNG-SGH-I337 using Tapatalk
                  Si vis pacem, para bellum.
                  New Hawtness: 1995 540i/6 Claptrap
                  Defunct too: Cirrusblau m30 Project
                  Defunct (sold): Alta Vista
                  79 Bronco SHTF Build
                  • jpod999
                    • Dec 2015
                    • 1401
                    #144
                    Originally posted by marshallnoise
                    Yep.
                    That makes fabbing up a blockoff plate a lot more appealing.
                    OBDI M62B44/6 swap
                    - jpod999
                    • marshallnoise
                      • Sep 2013
                      • 3148
                      #145
                      You can't do that. It's the pcv valve and needs to be there.
                      • jpod999
                        • Dec 2015
                        • 1401
                        #146
                        Ahh, interesting. I thought that MonkeyMadness had done that but he must have dealt with it in a different way.
                        OBDI M62B44/6 swap
                        - jpod999
                        • dothadance
                          • Jun 2011
                          • 1121
                          #147
                          For a second there I thought I had wasted $70 replacing the cover instead of just making a block off lol.
                          [QUOTE=36brua;4589709]
                          my experience w M60
                          blue vac line: cap
                          Appreciate the info! I gotta double check the orange arrow when I get home and see what's up with it. But damn is everything close together back there. "Tight fit" is an understatement lmao.
                          • marshallnoise
                            • Sep 2013
                            • 3148
                            #148
                            [QUOTE=dothadance;4589843]For a second there I thought I had wasted $70 replacing the cover instead of just making a block off lol.
                            The red arrow is for non-e34 cars that had this engine. They had bigger engine bays and were able to use a traditional brake booster setup. The vacuum for the brake booster on e34 m60 cars comes from the throttle body connection.
                            The orange arrow (easier pictured here), connects to the pipe that runs to the front of the engine and eventually connects to the Oil Separator Valve. It's the most important part of the PCV setup.
                            • dothadance
                              • Jun 2011
                              • 1121
                              #149
                              [QUOTE=marshallnoise;4589849]
                              Ah ok, so theres no opening on the side, but on the front for the pcv pipe! Right? I have the pcv pipe connected to the front, just couldn't remember if there was an opening on the side as well or not.
                              • dothadance
                                • Jun 2011
                                • 1121
                                #150
                                FUN TIME.
