ever sort that oil filter housing issue?
regular old m60 swap
Originally posted by ebelementsAlso, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
if i had more time, i would go to my local pick n pull and grab some oil lines from one of the seven e38s there and send it to you.Comment
my suspicions are correct! can just make brackets to move the filter housing over http://www.r3vlimited.com/board/show...&postcount=136Comment
Water pump and thermostat mounted. Need to take a BFH to my firewall to fit my rear coolant pipe.
injectors came back from being rebuilt!
So glad I decided to do this because two of my injectors were dead. Nothing better than putting in all this work swapping in a v8 for only 6 cylinders to fire, HA! Highly recommend MEPEH, great customer service and he gave me a killer deal on some good injectors
Why the brake pressure attenuator? Can you not use the bias adjuster on the wilwood pedals?
No rubber disk thingie, is this for exhaust manifold clearance or another reason? Is there a benefit to removing the flex disc that came on the E30?
Why modify the pan? Sorry for the noob question, but I thought the motor fits without needing to modify the pan.Comment
Not sure what you mean.. The new shaft is pretty much a necessity there's probably a half inch or so of space between the manifold and steering shaft. Answered the oil pan question previously, and it has been covered in multiple threads.Why the brake pressure attenuator? Can you not use the bias adjuster on the wilwood pedals?
[QUOTE=Eric;4557122]Why the brake pressure attenuator? Can you not use the bias adjuster on the wilwood pedal
That brake set up is on my car. Car has both wilwood bias valve as in pic and remote cable to bias bar located on pedal assy. The bias bar is next to lmpossible to manually adjust once installed with out remote cable
The valve and remote cable allow f/r brake proportioning. The stk E30 rear proportioning valve was removed
So valve for rough f/r set . fine set with cable/knob.
Will also make any brake upgrades easier to dial inComment
Thanks for mentioned these guys, looks like an awesome deal I might have to do the same.injectors came back from being rebuilt!
So glad I decided to do this because two of my injectors were dead. Nothing better than putting in all this work swapping in a v8 for only 6 cylinders to fire, HA! Highly recommend MEPEH, great customer service and he gave me a killer deal on some good injectorsComment
The last one was a 3 pin sensor? That's annoying! Who did you order from?Comment
old knock sensors lmao.
