Project Overly Ambitious
  • jpod999
    • Dec 2015
    • 1401
    #211
    The wife and the baby took a two hour nap together yesterday and I took the opportunity to go out to the garage. I got my shifter binding issue figured out and corrected it. I now have all gears. Later, my little dude met the E30.
    OBDI M62B44/6 swap
    Transaction feedback
    - jpod999
    • 36brua
      • 689
      #212
      ^^^ you need some comfort seats ! Remember--when outside
      Hat and socks at all times keep his ears covered !!
      Ahh thanksgiving in the garage.
      My CA legal M60 swap
      The happening in our garage
      • ThatM20Guy
        • Aug 2014
        • 601
        #213
        Haha that pic is adorable :o
        Cool build as well ;)
        89' 325ix Diamantschwarz/Black rattle can...
        Insta: r_moose_w
        Originally posted by flyboyx
        I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
        • JoeMadoo
          • 936
          #214
          +1 adorable picture
          '86 E30
          '05 E53 X5
          '72 Firebird
          '10 Prius
          '03 Tundra
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            #215
            So cute! I should try that with my 6mo old next time she needs a nap and I need car time :)
            • jpod999
              • Dec 2015
              • 1401
              #216
              Thanks everyone. Nothing more comfortable than an E30 Sport seat!
              OBDI M62B44/6 swap
              - jpod999
              • jpod999
                • Dec 2015
                • 1401
                #217
                Driveshaft is in! Just ordered parts that I hope will allow me to plumb the cooling system.
                OBDI M62B44/6 swap
                - jpod999
                • jpod999
                  • Dec 2015
                  • 1401
                  #218
                  Big moment today. I pulled the fuel hose off of the fuel filter and hot wired the pump to drain the tank of the two year old gas. I put four gallons of fresh Shell Premium, connected the DME and battery back up and turned the key. It cranked while it built pressure, then fired right up. The car moved under its own power for the first time since 2/21/16. I only inched it forwards and backwards a few inches, but it moves!
                  OBDI M62B44/6 swap
                  - jpod999
                  • Jean
                    • 18228
                    #219
                    Nice dude ! Congrats :) our cars are now twins , i drove mine around the block today :) Wait till you drive it and give it some gas ...
                    • delamaize
                      • Nov 2013
                      • 1438
                      #220
                      Congrads man! It's an awesome feeling!!
                      Dumpster Fire Pilot
                      • 36brua
                        • 689
                        #221
                        Major milestone now buckle in the car seat and take everyone for a spin!👍
                        • jpod999
                          • Dec 2015
                          • 1401
                          #222
                          Thanks guys! The rest of my coolant hoses are supposed to be coming in soon so hopefully I can get that buttoned up, then I can let the thing idle. If I can’t piece something together I’ll just bite the bullet and get a 740i water pump with the extra outlet. I wish I had known about it a year and a half ago!
                          OBDI M62B44/6 swap
                          - jpod999
                          • sticksdaman
                            • Apr 2005
                            • 2987
                            #223
                            say what? 740... extra outlet? What's the benefit of that?
                            also, congrats on the addition!
                            Originally posted by ebelements
                            Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                            • Jean
                              • 18228
                              #224
                              Check my thread :) I posted detailed photos of it .
                              • sticksdaman
                                • Apr 2005
                                • 2987
                                #225
                                Thanks for the quick reply.
                                Your thread is really well detailed. I need to go through it while I finish up my swap. There's so many different ways to do this.
                                Im following a similar route to you with the pas side mounted coolant res.
                                In the thread you mentioned "The 740i pump that I was able to source won't work with the thermostat / housing from the 540i pump as the design is different there. Tomorrow I am picking up another thermostat housing, it will have a temp sensor on it as it's really for m62 cars. I'll see how easy it is to remove the sensor or maybe use it as a signal source for a redundant coolant temp sensor (in addition to the one in the cluster that will run from the back of the engine, on the rear water accumulator pipe)."
                                How did you remedy this? Apologies if this is a derailment from OP.
