Not Another Cheap V8 Swap... (Pic Heavy)
  • E30Whore
    • Mar 2016
    • 183
    #121
    Fluids!!!!
    My Garage
    09 Mini Cooper S (Daily)
    09 E92 335i Msport
    09 E70 X5 4.8
    88 325es - Build Thread - http://www.r3vlimited.com/board/showthread.php?t=383423
    87 325i m50 swap
    87 325es
    • E30Whore
      • Mar 2016
      • 183
      #122
      Installing the harness which came with no directions and poor labeling proved to be a task. With two of us, we killed about 4 hours on something that I was certain would take a hour tops.
      Also installed the Sikky Air Intake kit. Love it!! This is actually looking like a completed car. Now just need to get fluids into the car, everything double checked, motor primed and then time for first start.
      We spent three long days this past weekend on the car and it shows. We accomplished a lot, ran into a few hiccups and even had to drill and tap the block but after all that, we overcame the task at hand!
      Looks like the wiring specialties harness came with a 5 prong connector but the MAF I have is a 3 prong. I already ordered a new MAF from a 02 camaro with a 5 prong connector.
      My Garage
      09 E92 335i Msport
      09 E70 X5 4.8
      87 325i m50 swap
      87 325es
      • E30Whore
        • Mar 2016
        • 183
        #123
        Pictured here is the clutch line and bleeder. We ran it up the drivers side header then wrapped it in heat shielding for additional protection
        My Garage
        09 E92 335i Msport
        09 E70 X5 4.8
        87 325i m50 swap
        87 325es
        • shiboujin
          • Feb 2006
          • 2791
          #124
          What's the cost and rating on that fan? Also make sure the fuel hose on that walbro is rated to fit in the tank. I used the kit hose and it blew on me after sitting in the tank for a week.
          • E30Whore
            • Mar 2016
            • 183
            #125
            I believe the rep at Bimmerworld quoted 540 CFM with this fan, specifically the straight cut model which is a louder but has higher cooling capacity. Here is the link:
            I was told the hose is rated for in-tank use but because I read similar reviews and comments like you just posted, I only used the kit line from engine bay to filter. I purchased high pressure fuel injection hoses from my local parts store to supplement the lines that came with the kit.
            My Garage
            09 E92 335i Msport
            09 E70 X5 4.8
            87 325i m50 swap
            87 325es
            • shiboujin
              • Feb 2006
              • 2791
              #126
              Good good you already thought of that.
              540cfm? Mine's rated at above 2500 and I have overheating issues. I really want to move to smaller dual 3000cfm+ fans as pullers. Pushers are much less efficient sadly. Shrouding will help too.
              • E30Whore
                • Mar 2016
                • 183
                #127
                That's suppose to be 5400.
                I hope it works out, they know I'm running AC and concerned about overheating. This is what was recommended. I'll be sure to watch closely and post a review later on.
                What size/brand fan are you running?
                My Garage
                09 E92 335i Msport
                09 E70 X5 4.8
                87 325i m50 swap
                87 325es
                • shiboujin
                  • Feb 2006
                  • 2791
                  #128
                  it's a flexalite 16" something. I didn't put the fan on so I'm not super sure what the rating is. I have the model number somewhere but couldn't link it up to a CFM rating.
                  • E30Whore
                    • Mar 2016
                    • 183
                    #129
                    Defiantly give Bimmerworld a call. Both Gary Grey and Philip Wertz are familiar with LS swap e30/36 cars and Gary new a bunch of spec's. He assured me I wouldn't have any over heating issues with this fan if I ran AC. Only time will tell I suppose but his confidence and knowledge gave me confidence in the part.
                    My Garage
                    09 E92 335i Msport
                    09 E70 X5 4.8
                    87 325i m50 swap
                    87 325es
                    • shiboujin
                      • Feb 2006
                      • 2791
                      #130
                      Hey hey. that sounds good to me! Thanks for the info.
                      • flyboyx
                        • 8371
                        #131
                        I went with the oem fan from an e32 740 or 750i.(also 840 and 850i) It's huge, pulls tons of air, only costs 50 bucks at the junk yard, it's plug and play, two factory speeds, and fits with a little bit of modification to the core support.
                        Gigitty Gigitty!!!!
                        • E30Whore
                          • Mar 2016
                          • 183
                          #132
                          This sounds like a great option. Do you have any pix of how it looks/fits?
                          My Garage
                          09 E92 335i Msport
                          09 E70 X5 4.8
                          87 325i m50 swap
                          87 325es
                          • flyboyx
                            • 8371
                            #133
                            Somewhere i do. Let me look.
                            Gigitty Gigitty!!!!
                            • jay_vee
                              • Mar 2015
                              • 12
                              #134
                              I'm currently sourcing everything I need to know to start my build I mean I have everything from freshly rebuilt f body t56 and an lq4 6.0 next would be a kit. And all the other fun stuff that comes with the swap lol I'm just curious what diff did you use ?
                              • E30Whore
                                • Mar 2016
                                • 183
                                #135
                                E30 325i 3.73 Diff
                                My Garage
                                09 E92 335i Msport
                                09 E70 X5 4.8
                                87 325i m50 swap
                                87 325es
