Since i'm doing a manual swap at the same time as my engine swap, I want to make sure I have everything in place when ordering the right parts. I have a few questions which I'm hoping you guys can help me out with.
1) The engine is out of a 95 540i and I sourced a 2000 540i 6 speed transmission. Now I understand that there is a difference in the spline count between the E34 and the E39 6 speeds, but aside from choosing the clutch, PP and FW setups, does this have an effect on anything else? For the record, I am going to be running the UUC LWFW with organic clutch combo.
2) What about the CPS sensor that is in the bellhousing of the E39 transmission. Since the M60 has this on the front of the engine, clearly I dont need the one in the transmission, but what does everyone do with it? Just leave the sensor in there to keep it plugged up or take it out and plug with a custom plate?
3) What slave cylinder do you use? I would assume you want to match it to the transmission so go with an E39, but I could be wrong.
4) What transmission mounts do you use? I tried to look for this info everywhere and cant seem to find it. E30, E34, or E39?
5) Lastly, since I need to order all the shifter parts for the car, I want to make sure I'm not missing anything. Again I am under the assumption that everything should come from an E39 to match the transmission. Here is the diagram from realoem regarding the E39 shifter assembly:
I purchased the E60 short shift kit and I have a DSSR that I will be shortening to size. I still need to buy#2 (Shifter arm, then shorten) #11 (rubber boot) and #14 (Shifter Arm Bearing). Now forgive my ignorance, but obviously one end of the shifter arm bearing mounts onto the shifter arm, but where does the other end mount to? Should this bearing be E39, or does an E30 one fit better?
I apologize for some of these noob questions, but this is my first swap and as I get closer to assembling everything, I’m getting more nervous and questioning if I’m doing it correctly. If you guys can let me know what you have done for these questions, and correct any of my wrong assumptions, I would REALLY appreciate it!
Thanks in advance!
Thanks in advance!
