M60 Jesus bolt, im getting desparate
  • dasmanschaft012
    • Apr 2014
    • 642
    I am trying to get the crank bolt off of my M60, and its just not budging. Killed 2 breaker bars, tried a 700ft-lb impact, tried 10ft pipes tried heating it up tried drilling the head out. its just not budging and im starting to think this crank is gonna be scrap if i cant get it out. Open to ideas. I'm currently looking to see if anyone has a 1000ftlb or greater impact. I just wanted to get the lower timing cover off to do seals and guides, but Im starting to think that I need to be looking for another crank now for a rebuild :( thanks.
    We're in deep now boys
    1988 325i SETA - Daily driver
    1988 340iL - Track car
    My M60 V8 swap thread here
    [oo==OO==oo]
  • TimeMachinE30
    • Jun 2014
    • 3749
    The M18 Fuel 1/2 Impact does up to 1200 ft/lb
    Their claims seem realistic. May be time to buy a new tool!
    ACS S3 Build / Dinan 5 E34
    • Reyhan335
      • Nov 2015
      • 700
      Time to get an air gun
      e30Ls1 Swap IG: 1dirty30
      • dasmanschaft012
        • Apr 2014
        • 642
        My air gun is 700ft lbs and it's not moving it.
        [oo==OO==oo]
        • Reyhan335
          • Nov 2015
          • 700
          Sorry. Time for a better air gun.
          • Jaker
            • Oct 2013
            • 234
            Or a bigger air feed to the gun. 3/4" air line will get you more CFM to the gun which will give you more torques!!
            • Reyhan335
              • Nov 2015
              • 700
              Is the motor in or out of the car?
              • dasmanschaft012
                • Apr 2014
                • 642
                yes it's out. i'm thinking next step is a bigger gun and a bigger hose
                [oo==OO==oo]
                • gath
                  • 577
                  Remember that the crank bolt is reverse threaded so you have to turn it clockwise to loosen it.
                  • Zacm829
                    • Jan 2008
                    • 1919
                    Worst case load up the engine and take it to a big rig truck shop.
                    1987 325i-M60b44 swap
                    • digger
                      • Nov 2005
                      • 6198
                      dont say that
                      just needs 3/4" drive heavy duty stuff and a thick walled pipe
                      • dasmanschaft012
                        • Apr 2014
                        • 642
                        Everyone keeps saying this. It's not. I have the replacement bolt in front of me, its regular right hand thread.
                        [oo==OO==oo]
                        • e30davie
                          • Apr 2016
                          • 1788
                          I couldnt get the main nut off the back of my gearbox and id tried all the diy things. I ended up taking it to a truck driveline machine shop. They had the biggest rattle gun ive seen and it came off in 2 seconds.
                          • noid
                            • 1537
                            Dont go incremental, get an inch impact wrench and apply all 2000 ft/lb of it.
                            Otherwise get a ladder and inch breaker bar and a 30 ft cheater bar.
                            Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                            Your resource to tools and tips: www.rtstools.com
                            • dasmanschaft012
                              • Apr 2014
                              • 642
                              Update: Got that f***er out. Torched it for 15 min, got the crank holder to press on the ground, and then jumped on the end of a 10ft pipe on a 3/4" breaker bar. Unthreaded by hand after the initial CRAK. thanks guys. Now to replace the chain and guides.
                              [oo==OO==oo]
