Does anyone here have any clear / detailed photos of the wildwood bracket from Garagistic lined up with the factory mounting holes under the dash from the factory pedal box?
I just tried fitting it (removed the dash first, and my car is non-abs so there isn't much there to begin with which is nice :) ) and ran into a small issue.
The bracket has 3 mounting holes, and instructions state to line it up with the factory holes. My car only has 2 holes there, the pedal box I've removed also was mounting with 2 bolts and not 3.
If I try to line up the bracket with the factory two bolts I have two options, either line it up and match the two holes but then the whole assembly is shifted too far LEFT and is in the way with factory wiring... (don't think this a correct location). The other option is to move the bracket slightly to the RIGHT and then it does not interfere with the factory wiring (it's the grounding point where all the brown wires connect), but then only 1 bolt hole lines up?
So, for those who have used this bracket can you please reply with
1) what year chassis you've installed it in, and did you use 2 or 3 bolts and how you have it aligned under the dash if you only used 2 bolts?
Pictures to follow.
Pictures to follow.
