M62B44,M60B40 heads & cams, Eaton M112 (now with NOS)
  • Mykk540i/6
    • Oct 2014
    • 175
    #106
    Started pulling apart my HE53 to transfer over the Getrag 420g & parts. I intend to use as many parts as possible from the E34, part out what I can't use and recycle the shell.
    The engine has formed a massive oil leak from a stripped out valve cover hold down stud in the cam cap, plus I already removed and sold the differential. So it needed a bit of a shove to get into the shop:
    Is the E34 forward mount brake booster assembly used in the E30 v8 swaps? If so, does anyone need it?
    • Elysian
      • 674
      #107
      Originally posted by mykk540i/6
      started pulling apart my he53 to transfer over the getrag 420g & parts. I intend to use as many parts as possible from the e34, part out what i can't use and recycle the shell.
      The engine has formed a massive oil leak from a stripped out valve cover hold down stud in the cam cap, plus i already removed and sold the differential. So it needed a bit of a shove to get into the shop:
      is the e34 forward mount brake booster assembly used in the e30 v8 swaps? If so, does anyone need it?
      ygpm :)
      • JGood
        • Jan 2004
        • 7959
        #108
        Could you do me a favor while that car is in that state of disassembly, and measure from the widest point of the passenger side valve cover near the front, over to the inner lip of the fender? I want to know the difference in the available space in that area between a 540i and an m60 e30, to see if a typical 540i centrifugal supercharger kit would fit in an m60 e30 bay.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • wworm
          • Dec 2016
          • 1719
          #109
          0o0oo0o0o0o0o0o this is the beginning of some fun thoughts.
          1984 Delphin 318i 2 door
          • JGood
            • Jan 2004
            • 7959
            #110
            It's been done several times, just curious how much I have to hack up the fender well area.
            Although after watching this thread and looking at the pics, that Eaton may fit under an e30 hood. What is the clearance like in the rear, does the S/C or intake parts stick out past the rear of the block? I'm not familiar with that setup.
            • Mykk540i/6
              • Oct 2014
              • 175
              #111
              You'll notice in the last pic the engine is out and separated from its trans. This weekend when I get back over to the shop I can set it back in the bay to get you your rough measurement
              • JGood
                • Jan 2004
                • 7959
                #112
                Doh. No worries. I'm sure I can find it elsewhere. You just get that built engine in something :)
                • dasmanschaft012
                  • Apr 2014
                  • 642
                  #113
                  soooooo hows it going?
                  We're in deep now boys
                  1988 325i SETA - Daily driver
                  1988 340iL - Track car
                  My M60 V8 swap thread here
                  [oo==OO==oo]
                  • Mykk540i/6
                    • Oct 2014
                    • 175
                    #114
                    It's going okay, a slow build. Acquiring parts as finances allow.
                    • dasmanschaft012
                      • Apr 2014
                      • 642
                      #115
                      those are some big johnnies
                      [oo==OO==oo]
                      • Mykk540i/6
                        • Oct 2014
                        • 175
                        #116
                        Replaced rear main & pilot bearing. Used wet TP to push out bearing. Installed clutch & trans. Just doing the minor stuff until I can get a frame.
                        • The Dark Side of Will
                          • Jun 2010
                          • 2796
                          #117
                          Before you make an unpleasant discovery on your own... the Jaguar suspension will *NOT* EVER work without the trailing arms. Go ahead and get those in your build right now because you can't use that suspension without them.
                          • Mykk540i/6
                            • Oct 2014
                            • 175
                            #118
                            Fully agree, thank you. The frame is made and set up for trailing arms as well as the front diff mounts and not just the 4 bolts in top of the housing.
                            • Mykk540i/6
                              • Oct 2014
                              • 175
                              #119
                              • dougie30
                                • Apr 2012
                                • 1708
                                #120
                                Originally posted by Mykk540i/6
                                Engine bay?
                                hahaha sorry didn't realize you where planning on putting the motor in a t bucket. carry on
                                M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
