5.3 LSA build
Looks wicked, taking notes for sureOriginally posted by e30guydownunderStupid German wookie winning F1 WDC and beating Webs. waffleswaffleswaffleswaffles.Comment
Spent some time today installing and mocking up the sequential shifeter
20190112_183623 by Supa Khan, on Flickr
20190112_182502 by Supa Khan, on Flickr
20190112_182411 by Supa Khan, on Flickr
Exhaust is here. Dual oval 3" all the way back to a Magnaflow muffler and dual cut outs.
20190112_184205 by Supa Khan, on Flickr
20190112_184232 by Supa Khan, on Flickr
20190112_184219 by Supa Khan, on Flickr
Was there a reason you chose shielding like that instead of a good ceramic coat?84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
_(edited)_IMG_20200926_170054(2).jpg?width=1920&height=1080&fit=bounds)
It does a better job of keeping heat out of the engine bay.Comment
Looks an amazing build, the car will be an absolute weapon & looking at the engine bay shots, a pretty decent power bulge will be required!
With the black / green wire for the unloader relays, splice it into the black / yellow wire so that it is energised during start. If you just earth it, the accessories won't turn off during start.
With the LSA swap it might not be an issue if you just ground the wire - especially if it's only a weekender - but with my M30 swap, when this circuit wasn't working properly I had really frustrating hot start issues in hot weather (over around 90F) that seemed like a "heat soaked" starter. After shotgunning a bunch of parts at the problem and not solving the issue, I sorted the unloader circuit with a new Black / Yellow wire from the C200 in the steering column to remove a bunch of solder joints from my auto to manual swap + I re-soldered the joint with the black / green wire and have had no problems since - the accessories behave exactly as they should & no more hot start issue.
You see a lot of M50 etc. swaps that have "heat soaked starter issues", but I suspect it's just because they haven't set up the unloader relay circuit properly.Comment
Thanks!Looks an amazing build, the car will be an absolute weapon & looking at the engine bay shots, a pretty decent power bulge will be required!
Worked on installing the remote brake balancer knob and a couple of gauges this weekend.
20190126_134501 by Supa Khan, on Flickr
Sep LOL. So I was waaaaay off on when I thought I would be done. Shooting for March. Hopefully I can make it to TX2K. Keeping my fingers crossed.Comment
