That looks great.
5.3 LSA build
Great job. Subscribed.How to remove, install or convert to pop out windows
Could be better, could be worse.Comment
Nice! How is the button panel attached to the dash?Comment
I glued it inside the frame (item 5). It has a recessed face
http://www.realoem.com/bmw/enUS/show...diagId=62_0110Comment
20190405_092624 by Supa Khan, on Flickr
So quick up date:
Re-wiring the car again and installing a ECU Master PMU 16. This will eliminate all the relays and fuses and make the wiring a lot cleaner. Once the wiring is complete the intake to the blower and the exhaust will be fabricated. Also changing the fuel lines under the hood to tubing for a cleaner and safer install.Comment
So a couple of things have changed. I decided not to go the PMU route, and I ended up going to another shop to finish my exhaust.
IMG_39891[1] by Supa Khan, on Flickr
IMG_39901[1] by Supa Khan, on Flickr
IMG_39881(1)[1] by Supa Khan, on Flickr
IMG_39871[1] by Supa Khan, on Flickr
IMG_40421[1] by Supa Khan, on Flickr
IMG_40361[1] by Supa Khan, on Flickr
IMG_40471[1] by Supa Khan, on Flickr
IMG_40461[1] by Supa Khan, on Flickr
If you click the above post it should play.Comment
