AN adapters for M60 oil lines
  • E30SPDFRK
    • 5715
    I know I came across the -12 AN adapters somewhere, but I didn't save it and now I can't find them. All I come across when searching is the -10 stuff for the 6 cylinders. Does anyone know who it is that sells the V8 ones?
    These are the 6cyl ones in case you don't know what I'm talking about.
    Byron
    Leichtbau
  • dmjensen
    • Jan 2011
    • 805
    I’ve got a set of these and they’re very nice ;)
    • E30SPDFRK
      • 5715
      I messaged him, but he hasn't logged on since January. Anyone have his contact info?
      Byron
      Leichtbau
      • dmjensen
        • Jan 2011
        • 805
        His name is Shady Hasan if that helps.
        • dasmanschaft012
          • Apr 2014
          • 642
          I ended up welding AN bungs directly to a X3 oil manifold. check out my build thread.
          If anyone feels like making a proper adapter to the oil filter housing, shut up and take my money. i welded AN bungs to the oil filter housing plugs with the o rings on them. and it sucks.
          We're in deep now boys
          1988 325i SETA - Daily driver
          1988 340iL - Track car
          My M60 V8 swap thread here
          [oo==OO==oo]
          • E30SPDFRK
            • 5715
            I did an s62 swap into an e34 last year, and one of the worst parts was getting those dumb lines to work. I ended up braising some AN fittings onto cut factory lines, and that was like my 4th attempt to make it work.
            Byron
            Leichtbau
            • The Dark Side of Will
              • Jun 2010
              • 2796
              Originally posted by dmjensen
              https://www.r3vlimited.com/board/sho...d.php?t=427076
              Still -10 though. OP is looking for -12's.
              • JGood
                • Jan 2004
                • 7959
                There used to be some reasonably priced adapters on US ebay, I don't see them anymore. There's some expensive ones oversees.
                I used AN fittings welded onto an X5 plate on the engine side, and brazed fittings onto the hard line ends on the filter side. It's been 7 years and 45k miles without any issues. I know it's not as nice as a purpose built 1 piece adapter, but it works, it's cheap, and you'll never really see them anyway.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • E30SPDFRK
                  • 5715
                  I had the numbers mixed up in my head, -10 is the correct size for the V8 still (was thinking 12mm). Its the o-ring side that doesn't work with the regular adapters, as the V8 is a 14mm oring and the 6cyls are 13.4mm.
                  Byron
                  Leichtbau
                    • Jun 2010
                    • 2796
                    Ah, ok.
                    • dmjensen
                      • Jan 2011
                      • 805
                      Went through my paypal statment and found his email for you.
                      shadyhasan93@gmail.com
                      Hopefully he can make you some more or send you files to have them made at your local machine shop.
