CX Racing LS Swap Kit
  • Pootis
    • 636
    So who is going to be the first to order one here? I like the look of the exhaust I may adapt it to my sikky headers if it is good quality.
    https://www.cxracing.com/engine-swap...-HD-LS-E30-KIT
    1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
    COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
  • z28
    • Oct 2014
    • 362
    Nice! competition is good
    First e30 - 1991 318i 4 door
    • The Dark Side of Will
      • Jun 2010
      • 2796
      That's a terrifying mount arm design. It'll probably fatigue and crack the crossmember mount pads in the first 100 miles.
      • jbontke
        • Mar 2019
        • 449
        Explain your reasoning?
        • varg
          Florida Turbo Man
          • May 2014
          • 3430
          I don't see an issue. If you put a V8 in your E30 and don't substantially reinforce the known failure point that is the crossmember engine mount, you don't deserve an E30.
          IG @turbovarg
          '91 318is, M20 turbo
            • Jun 2010
            • 2796
            Mount arms that put the mount on the crossmember essentially pull up and push down on the mount pad on the crossmember. Even they have problems at high power levels over time.
            Those mount arms, since they pivot at the engine, will put a TORQUE on the mount pad on the crossmember. Because of the aspect ratio of the arm and the fact that the loads at the tip of the arm are higher per ftlb of driveshaft torque because the pivots are closer to the crank centerline, that torque will significantly exceed the push/pull of conventional mount arms.
            IOW, it'll fatigue the mount pads and tear them off the crossmember quickly.
