No cluster lights
  • jeffw
    • 1087
    No cluster lights
    The lights in my gauge cluster don’t work. Everything else does. The obc and everything. Headlight switch?
  • twright
    • 707
    Burnt out light bulbs in the Cluster?
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      +1 for bulbs. It's not worth checking them, just replace them if you have the cluster pulled.
      Originally posted by priapism
      Originally posted by shameson
      • jeffw
        • 1087
        Do you know the part number and a good place to get them?
        • Vincenze
          • Apr 2019
          • 1044
          https://www.r3vlimited.com/board/for...-e30-bulb-list
          The small bulbs are 2721MF - they are everywhere on the Internet.
          The big ones under the orange covers are 2821.
          • jeffw
            • 1087
            I know the headlight switch is a common problem too. Is there a way to test the bulbs or the switch?
            • Vincenze
              • Apr 2019
              • 1044
              In order to test the bulbs, just connect 12V either way without any resistors.
              If you can adjust the brightness of the clock, then the switch works. It doesn't mean that connections to the instrument cluster are good. You can check the voltage on the appropriate connector pins when you remove the cluster.
