water pump access
  • projectJTv4
    • Sep 2019
    • 174
    water pump access
    Looks like I have small leak coming from the water pump. I can tighten 1 of the 3 bolts by removing the splash shield from underneath the car and looking up, but can’t see the other 2. I last did the timing belt and water pump in August of 2019 so I don’t remember how accessible it is.
    What do I need to remove to access the other 2 bolts to tighten them up?
  • TobyB
    • 5297
    The pulley?
    t
    • jeffnhiscars
      • Jun 2011
      • 6011
      If your WP is leaking after 4 years I doubt tightening the bolts will work for long. It also could be the bearing. Either way, 4 years you're about due for a timing belt.
      Alice the Time Capsule
