Starting Issue?
  • Auburn BMW
    • Feb 2024
    • 1
    Starting Issue?
    I have an intermittent starting issue. Sometimes, my 88 320i fires right up but then other times it cranks but won’t fire. Not a battery issue, as I have a new battery. I keep it in a battery tender, and the other day it started on the first key turn but then when I shut it off after 2 mins it would not re-fire.
    I’m wondering if it is my ignition coil?
  • 82eye
    • Jan 2009
    • 2108
    could be a number of things. first would be any number of possible air leaks. it's also a common symptom for a failing fpr or leaking injectors. smoke test the car to find and eliminate the air leaks, and tee a pressure gauge on to the fuel rail to test the fpr and injectors.
    • TobyB
      • 5297
      I vote crank sensor, but we're all just spitwadding here.
      t
