Power Windows Gremlin…..WTF…..
  • g.ruff561
    • 1268
    1990 Alpineweiss coupe. Automatic. Check this out. When the ignition switch is in position 1, my power window switches illuminate and operate up and down as they should. On start up, once the engine powers up and is running, the switches go black and do not work up or down at all. WTF….. I’ve checked fuses, relays????? Thanks in advance.
  • sna77
    • Apr 2023
    • 206
    I had a bad power window lock (circuit breaker)
    I ended up replacing the breaker: 61311369375 and all the switches:61311381205​
    1992 318i cabrio Alpinweiss 2
    2006 ZHP cabrio Imola​
    • g.ruff561
      • 1268
      Thanks for the feedback. I’m gonna swap in a known working circuit breaker and see what happens.
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4503
        Possible bad K5 relay?
        "We can see we are dealing with fuse 17, which has a rating of 30 amps. We can also see in the diagram that fuse 17 is "hot in run only from unloader relay K5" This means our windows will only receive power via fuse 17 when the car is in run, and relay K5 is switched on."
        From this thread:
        • g.ruff561
          • 1268
          Just swapped in a known working K5 relay. Problem still exists. Power in position one. No power after crank and running. WTH…. Bob do you have a good power window circuit breaker.? I have plenty of power window switches, but no pw circuit breaker.
          • AWDBOB
            hooptie connoisseur
            • Aug 2013
            • 4503
            I've got a tested circuit breaker! I'll text you tomorrow
            • g.ruff561
              • 1268
              This is weird. As soon as the starter turns to crank, the power window switches go black and do not work. 🙁
              • g.ruff561
                • 1268
                Just got a tip from Jon Gilbert. Could be the ignition switch. I just ordered a new one. I’ll give it a shot. If anything it’s money well spent. The car has the original ignition switch. A new one couldn’t hurt.
                • g.ruff561
                  • 1268
                  New switch should be in today. Updates to follow.
                  • g.ruff561
                    • 1268
                    Bump in the road. Ordered switch at the dealer. They said it would be in the next day. Went over the next day for pickup, found out part was out of stock. ?????? WTF????? Dealer ordered by Vin. It appears they may be vin specific. I have to try other sources. Dammmmnnn! I was pumped for the install.
                    • g.ruff561
                      • 1268
                      Ok update. I have swapped in a new ignition switch. Put all the pieces back together on the steering column. Ignition works as it should and engine starts and runs as it should.. Still power windows will not operate after the engine turns over and is running. New wrinkle……I have 2 dash lights that do not go out after start up. My abs light and my brake pad sensor light are constantly on while the engine is running. Normal operation is these light come on at start up, then go out.
                      FYI, my front and rear brake pad sensor circuits are closed circuit.s. Both circuits have been closed for 2 years. I visually check my pad wear. This light should not be on. WTF……..
                      • Panici
                        • Dec 2009
                        • 2569
                        Maybe worth the effort to check all the grounds in the car.
                        Seemingly unrelated electrical issues can sometimes be traced back to a flaky ground.
                        • g.ruff561
                          • 1268
                          Thanks Panici. I gonna start that this weekend. First thing I’m gonna do is jump the center console power window circuit breaker suggested by AWDBOB. Don’t get me wrong, my ac works well. I rarely use my sunroof or windows. As a matter of fact I don’t know many E30 owners who use their sunroof on a regular basis. I wish my 90 325i was a slick top.
                          • g.ruff561
                            • 1268
                            Anybody ever heard of a comfort relay? There are videos that show the E36 comfort relay location. But I can’t seem to find any info on the E30 comfort relay location or if the E30 has one.
                            • g.ruff561
                              • 1268
                              Update fail. Jumped power windows circuit breaker. Problem persists. No power to windows after crank and engine running.
