1988 E30 325i engine problem
  • richardkendrick
    • Sep 2024
    • 1
    Hello all,
    I'm new to this forum. I have a 1988 E30 325i. I'm trying to restore it the best I can, at the moment I can't get it to start properly, it starts but after a few turns to the key. We have checked the gas pump it is fine, compression range is at 160psi (would like to know the range when new) leaks are at 6%. I had a power cutoff on the engine so we also checked all electrical, connections, relays, ground, etc all fine, the starter, the alternator, all has been checked, we change the ECU and the cutt off stopped (yesterday did it once very light one) The "check" light on the dash goes off very often, push the buttom on the top control and goes back off.
    Any advice is appreciated! Thanks in advance!
  • 82eye
    • Jan 2009
    • 2069
    Originally posted by richardkendrick
    Hello all,
    start with these diagnostics for poor running and hard start: Diagnostics, tips, & tricks by Jim Levie (E30 Jedi Master) - R3VLimited Forums
    • moatilliatta
      • 6151
      PLEASE BAN
      @Zakspeed_US
