Odd E30 Wiper Motor Electrical Issues - halp
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4463
    Hey R3V-
    I have followed jlevie's wiper motor diagnosis procedure multiple times and poured over ETMs, but still have an electrical issue has plagued my '89 325iS since purchase.
    The wiper motor intermittently loses power. When testing this, if I remove/install the wiper relay, I temporarily get power back at the wiper motor (confirmed via multimeter).
    I have also ohmed out and continuity checked the chassis harness from the wiper motor plug to the fuse box, to the wiper motor switch and to ground, and compared these values to a car with a goo working wiper system to no avail.
    The wiper relay (and several others I tested) are good. Switch tests out good at relay pins in fuse box, but have also tried several spares to no avail.
    I thought maybe the wiper stalk g201 ground (steering column) was no good so I relocated it to the g200, which did nothing.
    Occasionally with the motor plugged in and running on low speed it'll "click out" like a glitch and softly engage the horn.
    The car has quite the checkered past- wondering if maybe wiper wiring over to the level sensor/pump may be causing issues with the whole system?
    Any ideas?
  • It's Soda Not Pop
    • Jan 2022
    • 875
    Clock spring maybe or a short some where in the steering wheel assembly.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • AWDBOB
      hooptie connoisseur
      • Aug 2013
      • 4463
      I've already relocated the steering column ground in the event it wasn't grounding properly there :/
      • It's Soda Not Pop
        • Jan 2022
        • 875
        Damn. Gremlins
        88' Seta 2.7i Zinno
