Which line is the return and which is the output on my early model in-tank pump?
  • rogerscgreg
    • Mar 2026
    • 20
    I've been searching everywhere for a diagram or indication of which of these lines is the return and which is the output.
    I figured the larger hose was the output, but I saw a video that said that was the return. Which is it?
  • reelizmpro
    • 9558
    Large one is the outlet and the smaller one is the return.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • rogerscgreg
      • Mar 2026
      • 20
      Thank you. I got zero psi on that fitting when I did a pressure test, so I guess I have a faulty pump.
      • 82eye
        • Jan 2009
        • 2108
        early dual pump in-tank pump can be replaced cheap with a chevy vega jobber pump. if you are in the states it's a stupid cheap proposition from a local parts store.
        could also use this as a prompt to update to the later single pump system. the cheap in-tank pump for that is a 90's 6cyl mustang pump. i've done this and it works great, even with some mild mods. avoids the trw / walbro costs everyone defaults to for the mod.
        • rogerscgreg
          • Mar 2026
          • 20
          Thanks. That's just to replace the pump in the housing, not the entire housing itself, correct?
          • 82eye
            • Jan 2009
            • 2108
            yes. just the electric driven pump itself. still needs to be modded to the bmw in-tank hanger. it's a well covered mod and easy to do, just be careful around fuel.
            something to note ;
            some guys cut the foot off the hanger and bend the remaining rod to support the pump. this will move the pump a bit higher and fuel gauge level will be a touch optimistic. when i have done the mod i usually keep the foot on the hanger and dremel it out if i need more clearance. this puts the pump at the stock level, but is a bit more finicky to accomplish.
            • weher9
              • Aug 2026
              • 2
              He estado buscando por todas partes un diagrama o alguna indicación de cuál de estas líneas es el retorno y cuál es la salida papa's pizzeria
              • weher9
                • Aug 2026
                • 2
                He estado buscando por todas partes un diagrama o alguna indicación de cuál de estas líneas es el retorno y cuál es la salida.
