SO...I wana go turbo.
  • f u z z
    • 1600
    Well ive been looking around on some turbo info for my 318is...and well i found nothing.
    I race autoX and drift, so it would be nice to have somthing to help me out on the low end. I dont want to push any crazy HP numbers, just somthing to have a little fun with. Any ideas or comments would be great.
  • Matto
    • Jan 2004
    • 800
    Try here http://www.e30tech.com/
      • 34839
      maybe you should fix that 4x4 suspension first?
      • Digitalwave
        is a poseur
        • 6299
        Turbo's generally aren't known for their help on low end power.
        RISING EDGE
        • Charlie
          kid tested, administrator approved
          • 6686
          For as much time, work and money it will take to make a turbo work properly on the high-comp M42, you could easily swap in a 24v 6 and be ahead of the game for a lot less.
          -Charlie
          Swing wild, brake later, don't apologize.
          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
          FYYFF
          • DanGillan
            • Mar 2004
            • 4061
            -Charlie
            thats not necesarrily true. at work we just did a turbo install on a e36 m44 (practiacally the same engine) and they customer bought a used mossleman turbo kit with some parts missing, long story short, the turbo is no installed, overboosting at 9psi (we want it to run 5) and the gains are pretty damn good, its a VERY VERY basic turbo, and it really helps. it wouldnt be a waste of time, but it would cost a decent amount.
            Dan
            • Charlie
              • 6686
              -Charlie
              M44's have knock sensors, which make a turbo a little less dangerous of a proposition, the E30 M42 motors do not.
              -Charlie
              FYYFF
              • f u z z
                • 1600
                in the process right now. Im half way there for H&R coilovers. 8)
                • DanGillan
                  • Mar 2004
                  • 4061
                  -Charlie
                  -Charlie
                  true, but the m44 also is known for blowing headgaskets like there's no tomorrow, the m42 is a little better about that
                  Dan
                  • spencers
                    • Jan 2004
                    • 1150
                    I'd drop a turbo before I drop the car. :P
                    • Wes325
                      • 563
                      you got the wrong E30 for a turbo IMHO
                      325is :)
                      - 318is 4 life
                      • Streetspec_iS
                        • 1622
                        twin cam, boost, m42. mmmm
                        keep the boost down, and the charge cool and youll be good. stock compression will be good for around 7psi and under. not alot, but it should see you around ~ 200hp.
                        strip some weight out the iS and you will have a nasty lil car. if you can, delete the a/c, as it will negate some of the weight of the turbo system in the front end.
                        good luck! keep us posted.
                        sigpicM42 Brigade ... Throwing craze in the 318
                        • Matto
                          • Jan 2004
                          • 800
                          -Charlie
                          I think that is the answer anyone gets when asking about any kind of major mod...
                          • f u z z
                            • 1600
                            this wont happen for a while, i gota buy suspension first. but i found a kit im calling on a price monday, but i might make my own custom. my freinf just turboes his 325, he did a great job, all work himself includign installation of a tuned megasquirt.
                            • StereoInstaller1
                              GAS
                              • 22679
                              Fuzz, does your buddy have his install on the web somewhere? Pics, man, pics!
                              Enquiring minds wanna know...
                              Luke
                              Closing SOON!
                              Thanks for 10 years of fun!
