whats this part called?
  • mang0boy
    • Oct 2004
    • 4
    whats the black fairly small hose that is connected from the manifold to sum sensor i think then the intake boot. cuz mine is cracked and making a really annoying sound.. i tried sealing it w/ electric tape for a temp fix but i really need to get a new 1.. cuz its still pretty loud.. thnx in advanced =P
  • James Crivellone
    Head Janitor
    • 6304
    Re: whats this part called?
    Originally posted by mang0boy
    [imsg]http://i1.ebayimg.com/02/i/02/b1/8d/89_1_b.JPG[/img]
    idle control valve?
    you mean one of the hoses that connect it?
    • fletcher miller
      • Sep 2004
      • 78
      Intake manifold
      • Digitalwave
        is a poseur
        • 6293
        Originally posted by fletcher miller
        Intake manifold
        You win the prize for the most idiotic post of the week.
        RISING EDGE
        • trent
          Intake manifold
          dumbass
          • fletcher miller
            • Sep 2004
            • 78
            YES
            • PanamaE30
              • Oct 2004
              • 768
              Vacuum Hose running from Intake Manifold to ICV. I had to replace mine recently. it was like $4 at the stealer...
              1988 325iC - "Betty" - Daily Driver/Project Car.
              1993 318i - "The Golden Dream" - Dad's Car.
              1995 318ti - "Hellrot" - R.I.P.
              • Bill 84 318i
                • 1600
                It's not really used for vacuum purposes, is it? It's just used as the bypass so the ICV can control how much air goes through when the TB is closed.
                • PanamaE30
                  • Oct 2004
                  • 768
                  I see your point.. but the air has to know how to flow one way or another right? lower pressure on one end... vacuum.
                    • 34839
                    hurrah for double posts! :roll:
                    • fletcher miller
                      • Sep 2004
                      • 78
                      koser had to replace that just take the hose into a pepboys and they will give you universal hosing for like 98 cents don't spend 4 dollars.
                      • Digitalwave
                        is a poseur
                        • 6293
                        I went to all the autoparts stores in town and none had that type of tubing or any tubing that would work. It's worth spending 3 extra bucks on OEM stuff.
                        RISING EDGE
                        • PanamaE30
                          • Oct 2004
                          • 768
                          That tube is of dual diameter. It starts at one size and ends up a different size. Sure you can go through the trouble of having a similar sized tube cut and stretched. Or you could just buy the damned OEM part, know that you have an original part that is known to work for 15+ years, and save time on fitment.
                          But that's just me.
                          • Digitalwave
                            is a poseur
                            • 6293
                            But that's just me.
                            The difference in 98 cents and $4 is huge to some people on this forum...
                            RISING EDGE
                            • fletcher miller
                              • Sep 2004
                              • 78
                              if its all the same than i would save my money and yes auto zone has it.
