E30 injectors, 22 lb ?
  • parkerbink
    • Jun 2004
    • 10138
    ad says 22 lb injectors is that the standard spec for our injectors?
  • Jand3rson
    • 37587
    Uhhh, no.
    I believe stock E30 injectors are 13lb.
    If 22lb was stock, why would everyone be upgrading to 19lb.?
    • parkerbink
      • Jun 2004
      • 10138
      So 19 pounds are what is coveted? are 22 pounds too much?
      Thanks
      • Jand3rson
        • 37587
        Thanks
        Stick with 19 lb. I'm a goon.
        • parkerbink
          • Jun 2004
          • 10138
          Ok, guy says they are for e30, M3, 325 but there are 6. I am confused.
          • parkerbink
            • Jun 2004
            • 10138
            I asked the seller if these will work, anyone know if I have a single hole injector which will work, or a four hole spray injector which he says will not?
              • 34847
              22lb might work, but you'd be pushing it.
              • parkerbink
                • Jun 2004
                • 10138
                I won the auction for 20.50 delivered so worst case I have 6 injectors to look at for 3.42 each. I will figure out exactly what they are from the part number when I get them.
                • parkerbink
                  • Jun 2004
                  • 10138
                  Since it's over I guess it's ok to post the link so they can be seen.
                  http://cgi.ebay.com/ebaymotors/ws/eB...tem=7930237385
                    • 34847
                    one important thing, make sure the impedance of M3 injectors is the same for a 325i, unless you want to fry your ECU.
                    • parkerbink
                      • Jun 2004
                      • 10138
                      The thing that confuses me it how can they be m3 injectors if there are 6? are there 2 extra?
                      My Hastings shows 14.5-17.5 for all but e's which are 2.0-3.0 but it has nothing on M3's Anyone know what it's value is?
                      • Rob
                        • 8166
                        is there something wrong with your current injectors?
                        BEERTECH
                        • parkerbink
                          • Jun 2004
                          • 10138
                          Nope but I am going to eventually do the mods to increase air/fuel flow and for the price figured i'd get the injectors now. If I can't use them I can afford to lose 20.50. Or I will put them back on eBay or something.
                          • M-technik-3
                            • 18946
                            Sounds like a waste of fuel if ask me. I need to goto bigger injectors in the M50 for the new cams next month. As the car is lean way out at 6200 rpm.
                            • Rob
                              • 8166
                              i've always wondered why the BMW tuner philosophy for tuning fuel is changing injectors. could a rising rate FPR or other true fuel tuning device work just as well, if not better?
                              BEERTECH
