Ignition Tuneup
  • Alkasquawlik
    • 4557
    Ignition Tuneup
    I'm about to do an ignition tuneup on my iX.
    Spark plugs, distributor cap and rotor.
    I'll be using the Bosch W8LCR spark plugs, already ordered from Pelican Parts and they should be here soon.
    Do I need to buy a brand new distributor cap and rotor or can I buy used off the forums if they are in good condition? Good or bad idea?
    I can't imagine it being too involved.
    I'll be using this as a DIY: http://www.pelicanparts.com/bmw/tech...ystem_Tune.htm
    Any other tech articles?
    SC*AR
    Originally posted by JamesE30
    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
    Use new parts and replace the plug wires also.
    • SpecM
      • Oct 2005
      • 4531
      also, change the fuel filter and re-set the valve lash
      1989 cirrisblau-metallic 325i
      • TrentW
        • 2815
        Beware--Bosch has discontinued the W8LCR spark plug (which of course was THE best for the E30) and Pelican is substituting the platinum plug (copper core w/yttrium). You'd be better off using the NGK ZGR5A which is a copper plug.
        • Alkasquawlik
          • 4557
          fuck really?
          when did they discontinue it? is there a way to stockpile some?
          SC*AR
          • Alkasquawlik
            • 4557
            Originally posted by Alkasquawlik
            fuck really?
            SC*AR
              • 34847
              NGK BPR5ES is also a good choice
              the bosch plugs aren't that great anyway
              • Alkasquawlik
                • 4557
                What's your basis on that?
                I've heard from numerous sources that they are the best choice for the E30 and that they are the OEM spark plugs.
                SC*AR
                  • 34847
                  they are ok, not great
                  I ran bosch for a long time. I went to 1 heatrange colder NGK, engine does run noticeably smoother. Plus they are cheaper and I can buy them OTC.
                  people usually reccomend the stock Bosch coppers because platinum/multiple tip plugs seem like an appealing upgrade. Except they are designed more for lower maintenance than performance, and also to lighten your wallet. And M20s tend to run like shit with them.
                  • Alkasquawlik
                    • 4557
                    so you run the NGK BPR5ES
                    SC*AR
                      • 34847
                      no I run BPR6ES
                      BPR5ES is the same heatrange as stock
                      • Alkasquawlik
                        • 4557
                        so the BPR5ES are the ones you suggest I get?
                        SC*AR
                        • TrentW
                          • 2815
                          Good news--my tech buddy informed me that Bosch has replaced the former WR 8 plug with the 7909 WR 8 LC + "Super Plus" plug. Still a copper plug and since I put them in my wife's '88 325 they run great. He said he prefers these over the NGK plugs anyday.
                          • SpecM
                            • Oct 2005
                            • 4531
                            the new copper/yttruim plugs are NOT platinum, and they accually run well
                            EDIT: oh just saw your post...
                            nando: I hav'nt tried any NGKs yet, tho. Bosch 7909's are OTC at my store, and only $2.19/ea
                            • Alkasquawlik
                              • 4557
                              What's the part number for the new Bosch's you speak of? The ones Trent mentioned?
                              SC*AR
