Ignition Tuneup
  • SpecM
    • Oct 2005
    • 4531
    Originally posted by Alkasquawlik
    What's the part number for the new Bosch's you speak of? The ones Trent mentioned?
    yes, those
    Bosch: WR8LC+
    Stocking Number: 7909
    1989 cirrisblau-metallic 325i
    • Alkasquawlik
      • 4557
      having a performance chip shouldn't affect spark plugs, correct?
      SC*AR
      Originally posted by JamesE30
      And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
        • 34847
        not significantly, you shouldn't have to go to a colder heat range unless the engine was modified with higher compression, cam, turbo, etc.
        • Alkasquawlik
          • 4557
          alright, good to know
          SC*AR
          • joonsup
            • 776
            I just picked up some NGK BPR6ES (recommended by Nando) from monument car parts over in san ramon during lunch today to replace the bosch platinum ones i put on a couple weeks ago. My car idles like crap so I'm hoping that the NGK ones will allow my car to idle and run smoother. I'll report back later this evening once I put them on.
            • Alkasquawlik
              • 4557
              Let me know how they work once they're in.
              I live in San Ramon and know exactly where that Monument is lol
              SC*AR
                • 34847
                those are 1 heatrange colder than stock actually, you'd want BPR5ES for a stock motor. But they might be fine too.
                • joonsup
                  • 776
                  Ok so I put them in and it started up smoothly. I'll report back tomorrow after driving around more.
                  • joonsup
                    • 776
                    Ok so yesterday I drove to work with the new plugs and I could notice the idle different. Lot smoother and stable compared to the bosch platinum I had on past few weeks. I ended up making another trip to the car store during lunch and bought the NGK BPR5ES since my motor is stock. So I swapped those in after work. I didn't feel any difference between the BPR6ES and the BPR5ES, but I guess for me it was more mental knowing that I have the correct plugs. My car still has no torque, but at least it feels smoother.
                    • SpecM
                      • Oct 2005
                      • 4531
                      Nando... why do you recomend the BPR5ES's over the "oem" ZGR5A's?
                      BPR's are "oem" for m10s, btw
                        • 34847
                        they work nicely, either is probably fine. I'm using BPR6ES's in my motor. BPR5ES is just the same heatrange as stock is all.
                        • Mike
                          • 932
                          So, what would you reccommend for a cammed n stroked m20?
                          Supatek -noun - your basic know it all
                            • 34847
                            BPR6ES for a "hotter" motor
                            • 87-325ic
                              • Apr 2006
                              • 1198
                              definitely go with a new cap and rotor, this and the plugs/ wires is one of THE BEST upgrades for any old e30
                              *by upgrade i mean gain in performance ( it is only really maintenance)
                              • Alkasquawlik
                                • 4557
                                I got new NGK ZGR5A spark plugs and put them on the car, but the ignition wires won't plug into them.
                                Wrong plugs or what?
                                SC*AR
