Cruise Control Problems
  • CC Rider
    • Nov 2004
    • 17
    New here so be kind to the newbie :^)
    Have an 1991 325ic Auto
    CC not working.
    Have checked all brake lights and cleaned all connectors.
    Also removed rear seat and checked main ground to brake lights.
    Fuses all good
    Replaced brake switch
    Replaced Under hood actuator
    Replaced computer
    Replaced steering column switch
    Did I miss something ???
    I noticed a switch on the gear selector under the center console. When I got the car it looked like the previous owner had spilled a drink down the center console and this switch open at the top. Does this switch have anything to do with the CC ?
    1991 325ic Auto
  • CC Rider
    • Nov 2004
    • 17
    Bump for some help please.
    1991 325ic Auto
    • Kondour
      • 243
      what about the cruise control lever switch? cool to have another member in sacto, Welcome.
      • CC Rider
        • Nov 2004
        • 17
        I replaced steering column switch - no luck
        SAC Rules
        1991 325ic Auto
        • Digitalwave
          is a poseur
          • 6299
          That might have something to do with telling the ECU whether or not the car is in park or drive. If its in park or neutral you can't use the cruise control. That may very well be your problem.
          RISING EDGE
          • CC Rider
            • Nov 2004
            • 17
            So if I unplug the switch it shouild, not allowing the ground to happen, tell me - right?
            1991 325ic Auto
            • Digitalwave
              is a poseur
              • 6299
              I think that if the switch is not functioning, its stuck in open switch mode, which won't let you use the CC. It'll always think that the car is in park or neutral. I have this same issue since I did the auto to manual conversion.
              RISING EDGE
              • BS87
                • 1606
                With the auto ---> manual don't you need to get the clutch switch for the CC to work?
                • CC Rider
                  • Nov 2004
                  • 17
                  It's an Auto Tranny
                  1991 325ic Auto
                  • James Crivellone
                    Head Janitor
                    • 6305
                    Nah, the CC Auto Disable is only active when it has 12 volts going through it, so if the wire is damaged/unhooked it won't get 12 volts, and CC will work in P/N
                    • James Crivellone
                      Head Janitor
                      • 6305
                      nope, just splice the connector so it thinks the clutch is always engaged
                      • CC Rider
                        • Nov 2004
                        • 17
                        Correct and if the switch at the gear select is damaged - this may be a way of diagnosing the problem
                        1991 325ic Auto
                        • Kondour
                          • 243
                          CC wont work under 28mph
                          • CC Rider
                            • Nov 2004
                            • 17
                            Correct
                            1991 325ic Auto
                            • parkerbink
                              • Jun 2004
                              • 10138
                              Where is the switch on the gear selector? I looked and don't see one.
                              I have trouble shot everything else and still have no cc I am about to do another 1400 mile Laredo trip and really would like to have cc.
                              Thanks
