stalls/dies when hot/under high load/at high rpm
  • Special_K
    • Dec 2008
    • 19
    so i just finished putting my 87 back together. runs great for about 5 minutes then dies as soon as it gets hot :[
    will stall if:
    the engine is hot enough
    engine speed exceeds 2500 rpm
    throttle is above half way
    here are some clues:
    injectors are from an 85 735i (they work, but i dunno if theyll work with my car)
    coolant sensor/sender are new
    afm works
    tps works
    vacuum leaks are minimal
    fuel pump (new) is quite loud/screeching
    fuel pressure regulator is new
    possible culprits i've thought of so far:
    o2 sensor (seems to work, could be wrong)
    coil
    injectors (maybe e23 injectors dont work on e30s)
  • moatilliatta
    • 6150
    You have an I or and E?
    m30 injectors are low impedance along with Eta ones, I motor has high impedance
    @Zakspeed_US
    • Special_K
      • Dec 2008
      • 19
      its a 325is
      • SpecM
        • Oct 2005
        • 4531
        get those injectors out of there
        1989 cirrisblau-metallic 325i
