Heat(fan) works when it wants to
  • Matt-B
    The Waffler
    • 3856
    So my fan works fine now, but ill turn car off, and go to use it the next day and it will not work on 1 2 3 or 4.
    I know if the resistor is bad it usually wotks on only 4, but do they intermitantly work?
    I saw a relay of some sort attached to heater box is that it maybe? I also checked fan switch and get a signal from all speeds..can that go bad or intermitantly go bad?
    any thoughts are appreciated.
  • 87bimmerguy
    • Jan 2008
    • 123
    Mine just started doing this the other day as well. Anyone know?
    • PeaveyBassist
      • Sep 2004
      • 3511
      Loose connection somewheres, or the blower motor going bad.
      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
      Welcome e30 (brilliantrot '90 325is) 12/23/06
      DaveCN = Old Man
      My signature picture was taken by ME! Not by anyone else!
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
      • freeski27
        • Sep 2009
        • 388
        got a blower motor and other heating parts for sale :). Let me know if you need anything.
        E30 325is "Starting from Scratch" build thread
        • Quadrajet
          • Jul 2008
          • 1278
          This last summer I was fiddling with my blower trying to get all speeds. I removed the resistor and saw there is a point set in there. It was corroded, so I took some 400 grit sandpaper and folded it in two and used it like a file between the points. Didn't take much, 4 or 5 times back and forth now all speeds work.
          Might give it a try, cheap fix, just takes some time.
          • reelizmpro
            • 9519
            I'll second that. The resistor pack consists of solid state coils. Over time the contacts get corroded so just resurface them. It's also a good time to check the brushes on the motor itself.
            88 M3 - LACHSSILBER/SCHWARZE
            • allwheeldrive
              • Jan 2008
              • 272
              Also try wiggling the 30a fuse while the blower switch is on and see if it kicks on. That was the problem on my car.
              • Matt-B
                The Waffler
                • 3856
                looks like ill be tearing into it this weekend and sand the resistor and where it plugs in to
                Whats the best way to check the blower motor, worked last night and not this morning
                and brushes on the blower motor?? is it like an alternator where they ware out
                • Quadrajet
                  • Jul 2008
                  • 1278
                  I'd have to dig up one I've got laying around, but if memory serves me right the brushes are not replaceable, or not easily, which ticked me off.
                  • Japandrew73
                    • 2164
                    Your motorsport stripes in your sig are oriented wrong, it goes blue, purple, red.
                    Got that bit of info from the Museum.
                    Sorry, it was bugging me :D
                    • Matt-B
                      The Waffler
                      • 3856
                      Not suprised you corrected me, Im not worried...
                      going to clean resistor beginning of this week
                      • bignate948
                        • Apr 2006
                        • 542
                        mine did the same and the motor was going bad
                        • evil_twin
                          • Nov 2007
                          • 2965
                          I just sanded my blower motor resistor connections down and it works great. Did a resistance test to make sure everything was intact and it's great. Put power on the 12v wire on the blower motor and it will move. If it moves, it's good. The blower motor is gravy to replace anyways.
                          Paypal: vdang5@gmail.com
                          Delta Auto Care
                          2875-C Towerview Road
                          Herndon, VA
                          703.435.1375
                          My Feedback Thread: Evil_Twin
                          • b*saint
                            • 3794
                            Did you bother looking at the schematics? Its o so clear when you check that hizzy out.
                            Ma che cazzo state dicendo? :|
                            • ieatpeople
                              • Mar 2008
                              • 883
                              i have a similar problem in my e28. sometimes the blower works, sometimes it don't. other times, without me even touching the blower control, it will go from off to full blast to off. what the hell makes it do that??
                              Originally posted by BillBrasky
                              That's like Vlad challenging Chip Foose to a car painting contest.
                              Originally posted by acolella76
                              i'm pretty sure 'Phillis' is short for syphilis
                              2007 CVPI, stock and slow
                              1994 tercel, 5efhe swap, i/h/e
                              1984 t-type, 5.3/th350 swap in progress
                              My newest addition:
                              Rebecca Arlene, born 4/19/2013
