87 325- fan clutch dead? should i go fan delete?
  • joecoolinatl
    • Sep 2004
    • 121
    today after taking my mema to lunch i noticed my temp start to go past halfway, then past the 3rd mark and then steam from under the hood so i pulled over into a parking lot. right at the thermostat housing the hose that comes outta the t-stat and points towards the radiator fan and then goes around the plug wires and down is burst right at the t-stat housing. i realize its because my engine fan isnt turning. i tried to move it by hand and it barely moves. so is my fan clutch gone?
    also would it be better to replace the fan clutch or go fan delete and lower t-stat? or go electric fan? i was thinking of ordering an electric fan if i can find one to fit
    joecoolinatl is online now Add to joecoolinatl's Reputation Edit/Delete Message
    Present:
    1984 633csi
    1985 635csi
    Past:
    1991 318i / 1987 325e / 1988 325is / 1986 325i / 1985 535i
  • Digitalwave
    is a poseur
    • 6293
    Umm if your fan isn't working and you are overheating, why would you remove it? I guess you could go electric fan, but it'd be easier and cheaper to get a new or working used fan clutch.
    RISING EDGE
    • Jon325i
      • 6934
      In terms of cost, it depends on who you inquire with. I've got plans to overhaul my cars' cooling system next week. One of the items being replaced is the cooling fan/clutch assembly. I located a new one for $80. I have also priced out electric fans. A good one from Spahl (sp?) runs close to $100 and then there's the custom mounting to sort out and wiring in a switch somewhere to turn it on/off.
      The only real benefit of going with an electric fan set up is if you're doing a twin-cam or M30 swap where space between the front of the engine and the radiator becomes limited. Besides, deleting the factory clutch-fan set up doesn't really yield any significant gains anyway.
      Jon
      Rides...
      1991 325i - sold :(
      2004 2WD Frontier King Cab
      RIP #17 Jules Bianchi
      • joecoolinatl
        • Sep 2004
        • 121
        ive thought about going electric even tho its a few bucks more for more airflow and noise
        i hate the damn noise of the factory one
        as for gains, im not worried about this this 325 is just the daily driver, my project cars are my 300zx and this 733i i got for free, and im pickingup this wrecked 325is from a guy next week
        but i looooove my 325 daily yaknow :)
        Present:
        1984 633csi
        1985 635csi
        Past:
