moto to VDO cluster ?
  • wodcutr
    • Apr 2009
    • 2193
    I swapped in a VDO cluster into my 325i and now it seems like the speedometer is reading about 10% faster than I am really going. Do I need a different coding plug? I know the moto's have an adjustable speedo and the vdo's do not, but I did not think it would be a 10% discression. Any ideas? Thanks!
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
  • McGyver
    • 4637
    how is the speedo adjustable? i have a moto and it shows 45 at 40 and 85 at 75. its a little annoying.
    • wodcutr
      • Apr 2009
      • 2193
      I have not done this personally, but from my searching apparantly there is a slide inside the cluster on the speedo that you can adjust + or - to compensate for differences in minor tire size. I don't think it adjusts more than 5% though!
      • McGyver
        • 4637
        well mine is off by roughly 10%.....
        • Atreus
          • 1846
          what is your tire size, differential gearing? that may play a role.
          1991 325iC - Mauritsblau sumthin metallic blue. DEAD
          1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
          1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
          1991 325iC - Calypsorot Metallic
          1994 540i - Granitsilber
          Originally posted by scabzzzz
          I've had blunts cock in my mouth, but I'm not gay.
            • 34844
            mine's only off by about 2.5mph (VDO). *shrug*
              • 34844
              only tire size matters. The sensor ring on all BMW differentials are the same.
              • McGyver
                • 4637
                stock bottle caps.
                  • 34844
                  Originally posted by McGyver
                  stock bottle caps.
                  the size of the wheels doesn't tell you much about the size of your tires :p
                  • antil33t
                    • 176
                    How to
                    There's a little trimpot under the speedo to calibrate it.
