So what else would affect fuel reading besides the sender and gauge?
Fuel level reading not correct, what's up?
Originally posted by arty818 View Posthmm yelow light is suposed to come on with less than 1.5 galons, if its just ur needle not working try using ur obc to see how much fuel u have i think its Range setting. that might give u something to compare to.
Sold.......again.
im having the same issue...just mine doesnt work, my gage is crazy, when its full its at full, and then it stays in the middle most of the time until the tank is almost gone it drops down i have to put fuel on the regular so i wont run out.....the po took the cluster out and installed a carbon fibre thing on it...
have you figured out whats wrong with yours?
Take the sender out, test it with an ohm meter.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
