Turbo, Individual Throttle Bodies or Swap? Cannot decide
  • ThatOtherGuy
    • 224
    Sup R3V,
    I just got an e30 a month back and have decided that i want to drift. I am looking for about 250-300 rwhp and trying to do it so in a timly manner.
    I can't really decide whether to do a swap, turbo my m42 or to throw Individual throttle bodies on.
    Any suggestions?
    Also, what will the tranny hold?
    Does anyone drift? And whats your set up?
    My suspension is also iffy, i don't know if a IE3 (i have the springs already) + Billy sports will suffice.
    I am gonna replace my control arms and tie rods and get a LSD (what is the best ratio?) and get some front and rear strut bars and some 25mm and 22mm sways with poly bushings.
    I'm new to bimmers and to the sport so feel free to point me in the right direction,
    Thanks mates
    Max
    27
    Turbo M42
    37.04%
    10
    14.81%
    4
    Swap (m50,s50)
    48.15%
    13
    Originally posted by jasonsnoddy
    I don't always drift, but when I do, I prefer ford fiestas
  • Kershaw
    • 11822
    turbo. gt3071r.
    AWD > RWD
      • 34847
      ITBs aren't going to give you a 100+hp gain by themselves. on a stock motor you might see 10hp. on an M42 it may be less.
      the stock M42 tranny is pretty weak though, and you definitely don't want to use the stock M42 diff with anything over about 150hp.
      • briansjacobs
        • 1278
        I think the cheapest answer for that kind of power is a turbo M20 swap. 3.73 or 4.10 diff locked not LSD. You can do a S50/S52 swap but that will only net 200 RWHP stock.
        Brian Jacobs
        • ThatOtherGuy
          • 224
          Shit. So it seems like the m42 is kinda junk. So if i throw in an m20 then turbo that bitch we should be talking some good numbers.
          And when you say locked are you talking about welded?
          • SamE30e
            • Sep 2007
            • 4319
            Mines holding strong at 200...
            1985 325e 2.8 Turbo VEMS
            • kamotors
              • Nov 2007
              • 7102
              turbo
              7speedshop.com
              • briansjacobs
                • 1278
                locked=welded
                and a turbo on a "stock" M20 should give you 250 RWHP. I can tell you that with 200RWHP and a locked/welded 3.73/4.10 it will be slideways all day.
                I have a 4.10 LSD and there are certain turns that I drift in 4th gear with 180RWHP, I can not imagine if it the diff was locked and if I have another 75rwhp
                Brian Jacobs
                  • 34847
                  the tranny probably holds a little more but definitely not the diff. there's plenty of people who've broken them with a stock M20. plus this dude wants to drift..
                  • ThatOtherGuy
                    • 224
                    Yeah. So i'm thinking something like a 3.73 LSD not locked becuase there is going to be some DDing in this car.
                    Set up is gonna be a m20 2.5 with a 2.7 head with a thick headgasket boost about 10-15 lbs.
                    What tranny do i need to get to hold that much power??
                      • 34847
                      don't do a 2.7 head. just get a stock B25, the 2.7 head is garbage.
                      • ColdAccord
                        • 5926
                        m50 turbo
                        Originally posted by blunt
                        • ThatOtherGuy
                          • 224
                          Well i'm still not certain on whats a good set up yet but def gonna go with a I6 turbo set up. thanks for the replys
                          • Danny
                            • 14216
                            Reading the ops posts is painful.
                            • Aptyp
                              • 6584
                              I fantasize about built m42 with a snail on it.
