Roof sheetmetal change?
  • Jean
    • 18228
    Ok, not saying that I'll have to do this...but ...
    What does it take to replace the outer skin of the roof on the e30?
  • Hellabad
    • 807
    I've done it a few times, it takes a while.
    Basically you remove all the windows (I pay a guy to do that), and cut through the pillars as close to 90 deg as you can, about 2/3 of the way up.
    Then weld on a whole new roof. This keeps the body work on a flat, easy to redo area.
    Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
    Ground Control Gallery
    The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
    • Erik j
      • Jan 2008
      • 939
      If its rattling right there you just need to put some foam rubber in there, no need to replace the roof.
      Tri color fabric for sale here!
      http://www.r3vlimited.com/board/showthread.php?t=105922
      • Jean
        • 18228
        Erik J - the rattle seems to be coming from #7 (under 9) against #1
        http://www.realoem.com/bmw/showparts...02&hg=41&fg=30
        I have no idea why that would even be the case....So, putting foam inside #9 might not even fix this.
          • 34847
          FYI the sunroof seal is for air, not water. if your sunroof leaks water then your drains are blocked.
          I'd fill that gap with expanding foam and call it a day..
          • Jean
            • 18228
            It's not leaking from the roof...the problem is the sheet metal inside #9 is rattling away . Drains are fine.
            There is also no rust, other than on the sunroof crank pipes.... i wonder if stiff suspension was the cause of this? odd.
            • Erik j
              • Jan 2008
              • 939
              There is a expanding foam that you can spray in there that will stop these rattles, the factory uses this stuff all the time on roof skins, I have used this many times when I used to work at a body shop. Go to your nearest body shop and ask them about this foam stuff.
                • 34847
                oh I know, that was in reference to your other thread where you asked about sunroof seals.
                if the peice isn't physically falling off, just foam it. :)
                as to your other q, yeah stiff suspension probably caused it. I'm looking forward to the day I can seam weld my car and put in a full cage. at ~230k it's starting to get a bit sloppy, the doors don't even close the same now.. :(
                • george graves
                  • 20003
                  Jean - I can't hear a damn thing in my car it's so loud - I bet most of these e30 are that way too. How in the world is one rattle causing you so much grief?
                  Originally posted by Matt-B
                  • StereoInstaller1
                    GAS
                    • 22679
                    My car is nowhere near loud...unless it is running, or the stereo is on.
                    Fuck it Jean, buy a decent subwoofer!
                    Closing SOON!
                    Thanks for 10 years of fun!
                      • 34847
                      why is your car so loud? with 3" exhaust the loudest thing on my car is the intake. lol
                      • Jean
                        • 18228
                        Lol.. I can't stand rattles, especially if it's a metal on metal kind..it really is annoying. Plus, it's right there infront of me I can't ignore it :)
                        My car isn't exactly quite either, dual 2 into cat, into single 2.5 out exhaust, it's nice when I am easy on the gas and it gets loud at 3k+ plus.
                        So, what kind of expanding foam should I ask for.. I googled it last night and there are two kinds i guess, the ones that become hard when expand and the ones that stay somewhat soft?
                        Luke - I have two subs, not in use collecting dust. One is an older polk db, and one is a massive "Blueprint 12" that I build a 3" cube box for home use, it's massive lol.
                          • 34847
                          I'd think one that stays soft, you're trying to cushion a rattle, not support something.
