Why is one Side Higher Than the Other.
  • fiftytakedowns
    • 2460
    This was a problem from before I ihad the car, and I have sort of lived with it. but yesterday I busted out the measuring Straight bar, and found out that the right side of the car is 1 inch higher than the left in the rear, and about .3 inches in the front.
    I redid the entire front suspension, and the rears now have bilsteins, and turner jstock springs....
    what gives?
    [/url]
    Team USA Wrestling 67KG
  • McGyver
    • 4636
    fat chick stuck in there?
    • fiftytakedowns
      • 2460
      Badduumm chhh
      [/url]
      • KenC
        King of Kegstands
        • 14396
        Tweaked trailing arm?
        You sure the ground is 100% level?
        What sways do you have?
        Originally posted by Gruelius
        • fiftytakedowns
          • 2460
          I have a Stock sway bar in the rear, What should I look for ? Its always tilted a wee bit no matter how level the ground is.
          I do however have a rear strut brace.
          [/url]
          • b*saint
            • 3794
            Ma che cazzo state dicendo? :|
            • E30Nova
              • 1546
              Subframe bushings/RTAB's could be shot?
              Matt
              I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
              Originally posted by kronus
              try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
              This is like a reverse build thread; it starts out nice and gets shitty.
              • ///digitalme
                • Dec 2009
                • 2088
                same issue here i was told subframe bushings also...and back is about 1 inch off from the other side....also have a thump sound coming from the back when shifting..
                • caliGreen
                  • 195
                  oh is that how you fix it? as in the thump after shifting.. thought it was diff or something.
                  • Kershaw
                    • 11822
                    a thump heard when there is a load transfer is generally the subframe bushings. when you shift, load is taken off the rear. you can also just hit the gas and then get off the gas repeatedly. thumps should be heard then too.
                    AWD > RWD
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      subframe bushings x344938202
                      check and make sure they havent backed out of the subframe and the collars are in place correctly.
                      Mine was about 2inches lower on the drivers side because of this.
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • HarryPotter
                        • Jan 2010
                        • 3642
                        Fuck subframe bushings, I've had mine sitting in my room for a year and haven't tackled the damn job yet.
                        John F. Kennedy
                        • fiftytakedowns
                          • 2460
                          Thanks for the advice, When I go to tackle the rear Susp. Ill know to do all that shizznit. Ive heard the rear sucks a bunch
                          [/url]
