new wheel horn stays on
  • crazyvwobie
    • 298
    I just put a sparco wheel and hub on my airbag 91 and when the ignition is on horn stays on but works like it suposed to with the stock wheel. anyone have any ideas ?
  • xxx-Lost-Soul-xxx
    • Apr 2008
    • 1953
    Did you make sure the Horn wire is in the right plug? I had the same issue with a Momo wheel.
    • Dj Buttchug
      • Jun 2010
      • 7682
      you have it wired wrong. One wire goes to ground the other goes to power. If you wire it backwards when you bolt everything up it automatically grounds the 12v and your horn turns on.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • crazyvwobie
        • 298
        the sparco only comes with 1 wire and i put it to the ground on the horn.Do I need to add positive wire and what does it conect to? thanks guys
        • hurttech
          • 237
          The one wire should go to the button postive, im pretty sure the button grounds through the wheel/hub.
          • evil_twin
            • Nov 2007
            • 2965
            It does. Make sure that wire doesn't touch anything either. I had that problem on my steering wheel.
            Paypal: vdang5@gmail.com
            Delta Auto Care
            2875-C Towerview Road
            Herndon, VA
            703.435.1375
            My Feedback Thread: Evil_Twin
            • crazyvwobie
              • 298
              so the contact on the hub is positive and then i need to add a ground?
              • crazyvwobie
                • 298
                I can put the wire on either and still the horn just goes off even with the horn button mounted.I can take the wire and touch the colum and has no effect.
                • b*saint
                  • 3794
                  My weapon has no effect.
                  Ma che cazzo state dicendo? :|
                  • ROLLingKING
                    • Apr 2011
                    • 1169
                    what ever came of this??
                    im trying to install my horn and when i hook up the ONE wire thst i have with the momo hub nothing happens when I push the horn
                    if i touch the wire to the steering hub tho it goes off...i dont understand what is supposed to be hooked up to what....why not just provide instructions when you pay money for shit. i dont need a thank you letter for choosing momo. fuck
                    m20 is plenty. im simply a drifter.
                    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                    • e-durty
                      • Mar 2008
                      • 110
                      your steerign wheel is installed incorrectly, basically its on to tight and it is using the steering wheel as a button for the horn.
                      • ROLLingKING
                        • Apr 2011
                        • 1169
                        nvm
                        used a paper clip and twisted it to one of the connectors on the back of the horn and then twisted it around a section of the inside of the hub.
                        i put the single wire on the other connector on the back of the horn and presto!
                        • ROLLingKING
                          • Apr 2011
                          • 1169
                          i torqued it to spec tho..
                          it worked with a paper clip..and when I called momo they said there should be 2 wires..they told me to call turner or VAC.lol what a joke
                          • ROLLingKING
                            • Apr 2011
                            • 1169
                            paper clip
